Hydraulic lift does not stay up.
Marcel21674
Netherlands
I recently bought an old kubota B6000 4WD. It's in fairly good condition, but 1 thing anoys me.
The hydraulic lift does not stay up, it keeps slowly getting down.
What is most likely the problem, the cilinder or control lever?
Thanks.
6,519
Thanks.
Most likely is the piston seal but there are miltiple other possibilties.
6,074
'old', how old ? An idea how many times the 3PH was used ??
providing there's no obvious leaks, the rockshaft cylinder seals would be the 1st guess.
rbargeron
Jul 6, 2015
1,183
260
western ma
Welcome to the forum - 3-point hitch droop can be easy to fix.
If it goes up but doesn't stay up, the O-ring on the lift piston could be leaking.
It's part 19 in this diagram - 12 cap comes off with 4 screws and pushing the arms further down will push the piston out exposing the 0-ring. If you can get it out in 1 piece, car parts stores can often match it up from their assortment.
Or its actual part number can be ordered at Messick's
Happy tractoring - Dick B.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,276
178
Coyote Flats,Texas
Welcome to this forum
Does lever move forward or remain in place when 3 pt hitch lowers?? If lever moves forward friction washers on lever are worn & need to be tightened.
6,519
I dont think there are any friction washers on the B6000 valve. The lever is one piece and solidly connected to the spool via a pinned in place lever arm. Not much to go wrong there.
hi
Marcel21674
Netherlands
I dont know the exact year, but what i could find it should be between 1973 and 1977. So fairly old yes.😊
I know nothing about the history, but i don't think it had a heavy life.
I'll replace the o-ring.
2,652
Thanks I'll start with replacing the o-ring on the piston.
There may be one or two (plastic) backer rings to install next to the o-ring. They fit into the same groove as the o-ring.
Marcel21674
Netherlands
i have replaced the o-ring and that fixed the problem.
The old one was realy worn. replaced the other o-rings as well should be good for for the next couple of years.
Their was no backup ring on the piston, is that a problem?
Next i have the finish the rebuild of the front axle.
Was full of grease insread of oil
2,652
No problem if there is not a backup ring involved.
