BX overheat fix (band aid)
shelkol
bx-2200, Woods BH6000 backhoe, Tach-N-Go quick attach bucket, snow blower
Nov 12, 2015
211
187
Westford, Massachusetts
shelkol.com
I was doing leaves and of course it started getting warm since the radiator was getting plugged up. Not wanting to stop and clean the radiator while it was hot and after some consideration, I turned the heater on. Cab doors off for the summer, so not problem. Temp stayed in the black!
2,897
CLEAN that radiator - I have machines that I work on that people will continue to cut grass/leaves with the overheat lamp lit on the dash - they run it till the override kicks in and the computer kills the engine.
Radiator is a must be "clean all the time" device on the tractor!!!
shelkol
Nov 12, 2015
211
187
shelkol.com
I agree, just wanted to get the leaves done that day. Will be cleaned this weekend
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,874
2,301
Near Lancaster, PA, USA
If you want to go beyond a quick cleaning:
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Too much compressed air being used on a radiator can lead to bending fins or worse. Same said for spraying the fins with a stream from a water hose.
Bri-Guy-GA
Kubota BX1880
Sep 10, 2020
195
139
Villa Rica, GA
Given there is hardly any space to get in there what is the best way to clean the radiator fins on a BX?
Trimley
Jul 25, 2023
1,181
872
PNW-WA
I don't have a simple solution to that. I do know a cleaner/de-greaser can be used, and be very effective, but it can also damage other surfaces it gets on.
The answer may be as simple as Dawn Dishwashing Liquid/water, applied with a pump sprayer? I've not personally had a need, yet. It could work very well, rinsed/a light spray from a hose after soaking?
