L3901, 2017 Fuel System Component, what is this component?
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
110
47
Fort Calhoun, NE, USA
It almost looks like a pre filter...because 1 is the diesel filter and to the left of your arrows is the water catchment.
thackney
B7100, L3901, RTV500, Z122S
Nov 23, 2010
9
Rosharon, TX
www.facebook.com
Well, thank you for taking the time to educate me. I have not seen the wires while going over the actual part but I have not taken it apart.
I replaced the fuel separator and the fuel filter. I had an algae problem, but after replacing it never starts, while turning over. I will take it apart and try cleaning. hopefully it does not need replacing.
Thank you again.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Thank you again.
Turn key on, does it thump, thump, thump like it is pumping fuel? If so, it’s probably fine. Did you bleed fuel system after changing the filter?
6,287
that pump could be full of algae. see if you can clean it, bench test with fresh fuel,you should get good pulses of diesel.
I've used these...
as 'transfer' pumps in the past and ran a 30HP forklift for several years.
Might be worth the $10 CDN, if only to prove you may not need the $200 pump.
TimAT
GF1800 4x4 60" Mower F2560 4x4 72" Mower Push Blade Fabbed from a JD mower
Oct 5, 2023
51
22
Kansas City. MO
I found a replacement pump on Amazon for $15. Holdwell brand IIRC. Had to drill one of the mount holes a little bigger for my application, but works fine. Key on and "tick-tick-tick".
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
I have followed the instructions. I did not see any diesel come out the bleed vent like I expected.
Remove filter and see if you have fuel in filter. If not pump may be bad. If so, bleed system again until fuel is coming out bleeder.
thackney
Nov 23, 2010
9
Rosharon, TX
www.facebook.com
I disconnected pump from the tractor body and removed the discharge hose. I can feel the pump trying to run in my hand, vibrations. No diesel discharge.
I took off the intake hose and diesels flows freely from the water separator to the pump.
I could not blow air through the pump forward or backwards.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Sounds like you need a pump. It should be a distinct and audible thump, thump, thump… while pumping.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
If you would help me with something stupid, I bought the fuel lift pump but cannot figure out how the electrical connector comes apart.
Can you post a clear picture or two of the connector? Could be a push button to release or you may have to pry a tab up to separate them.
