B2650 shortened control arm?
AK Poser
B2650HSDC
Sep 10, 2024
17
Fairbanks AK
I’m new to tractors but not to heavy equipment. My control lever hits my steering wheel (knocks my 3rd function LP button off) when maneuvering the hydraulics, and wondered if any one has cut the shaft shorter to create a shorter throw to prevent this nuisance?
3,058
can you take a picture of what the problem is - maybe a couple of pictures.
nbryan
Jan 3, 2019
1,425
944
Hadashville, Manitoba, Canada
My 2017 B2650 loader hydraulics control lever won't get any closer than 2-3" from my steering wheel when pressed firmly to the left (curl bucket) position.
I'm guessing either your lever got bent hard to the left at some point and never sprung back, or there's looseness at the lever bottom mount at the hydraulic valve body, or that valve body is loose or mounted with a tilt towards the inboard side.
If the valve body and lever mount plate seem to be mounted properly then I'd take that lever off and bend/twist it so that 2-3" clearance from the steering wheel (in hard full-left/bucket curl position) is recovered.
11,042
Sounds like something is amiss with the linkage.
It shouldn't hit the steering wheel.
AK Poser
B2650HSDC
Sep 10, 2024
17
Fairbanks AK
Thanks for the reply, will investigate further.
nbryan
Jan 3, 2019
1,425
944
I see, yours is a cab model so my loader lever and clearances are completely different for my open station.
PHPaul
Apr 2, 2015
1,283
1,596
Downeast Maine
www.eastovershoe.com
I'll check mine and take a picture of full-left travel. Cab model, but no 3rd function.
Lever in neutral position, steering wheel in lowest position. Distance from knob to wheel and knob to window.
Knob to wheel, full curl position.
Knob to window, full dump position.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,976
Near Lancaster, PA, USA
This is a GUESS. It appears that the original knob was removed and replaced with a much longer assembly that includes the TF buttons. If that whole tall mess on top went away you'd have clearance?
Could it be that the TF assembly is either made for a different tractor, aftermarket, mounted incorrectly or engineered poorly?
EDIT TO ADD: To answer your original question, I'd make sure that shortening the lever doesn't affect anything (doubt it would) then I'd whack it to suit.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
283
Bigfork Minnesota
If you had an original OEM Kubota third function installed you would not have this issue. My B2650 cabbed installation does not hit the steering wheel. My guess is that most if not all aftermarket third function installations will suffer with this issue.
chim
Jan 19, 2013
3,278
2,976
At least the top part looks like the one that mcmxi posted of his control in another thread. Might it be an official Kubota part but meant for a different model?
AK Poser
B2650HSDC
Sep 10, 2024
17
Fairbanks AK
AK Poser
B2650HSDC
Sep 10, 2024
17
Fairbanks AK
Interesting. It’s a Land Pride TF for the tractor, so I thought it was made with Kubota in mind. Thanks for the help!
AllenBC
L3901, L525 Loader, BH77 Backhoe, Lane Shark LS3, Pallet Forks, Snow Plow,
Jul 10, 2024
66
27
Warwick, New York
An easy way to avoid TF shut off when bumping the steering wheel: turn the knob so the buttons are on top. That should be easy to do by backing off the screws that hold it to the joy stick. The wire loom running down the joy stick will be twisted a bit but you should be able to sort that.
AK Poser
B2650HSDC
Sep 10, 2024
17
Fairbanks AK
Done. It does fix loosing the buttons or hitting the third function on accident, but thought it was strange that the controls came in contact with the steering wheel at all. Thanks
AllenBC
Jul 10, 2024
66
27
Warwick, New York
I have a 3901 and my loader joy stick doesn't come close to bumping the steering wheel, but it's mounted entirely differently so that's not relevant. Looking at pictures of B2650 it seems that the cab model stick is taller than the open station. FWIW, when I added the C-Function kit to my WR Long 3rd function valve, the directions suggested cutting the arm shorter if that made it easier to use. It would have been easy to do, but seemed pointless for me. Maybe it's not pointless for other Kubota models. Anyway, having the loader stick bump the steering wheel would annoy me a lot, buttons or no. I would look at the same model at a dealer to see if something is wrong,
