L3010 No lights No Crank
2,112
I would assume that the fuses are in the fuse box but Kubota does use in line fuses for some reason in some cases of wiring.
I agree that the key switch wiring should be correct s it is a connector (mine is screw terminals).
So now I would check the power into the fuel cut off solenoid and see if it is getting power at all. I guess you could try to just clean the connector and the ground point (may be the case is the ground path). The diagram posted above in post #17 explains the details fairly well.
N3BP
Sep 20, 2016
486
213
Lebanon, PA
The two fuses referenced (#6) in the workshop manual are in the main fuse box. The only fuse on a 3010 external to the box is the slow-blow.
You'll have to pull the dash again and examine the shutdown circuit and module. If I remember correctly, it's in the vicinity of the stater relay and glow plug controller.
michaelr
1998 L3010 GST
Oct 17, 2024
12
Greenbrier County, WV
OK, thanks.
michaelr
1998 L3010 GST
Oct 17, 2024
12
I will take a look at it. Thanks.
