I tend to hear and read this a lot, that Kioti tractors have more and better features for significantly less money compared to Kubota tractors. I'm not that familiar with all Kioti models, but since I have an MX6000HSTC I figured I'd compare it to the equivalent Kioti model which appears to be an NX6010CH.
This is just one example, but the table below tries to make a fair comparison between the two models. If I add in the standard features that come with the Kioti to the Kubota build, and even include a rear wiper not available from Kioti, the price difference is only $1,174. Bare in mind that the Kubota has a 2.4L 4-cylinder engine putting out 63.4hp gross compared to the Kioti with a 1.8L 3-cylinder engine putting out 60.0hp gross. Which one should last longer and have more torque? Also, Kioti implies that only two rear remotes can be added compared to three rear remotes available for the Kubota.
It's hard to compare the FEL capacities, but notice that the Kioti L6010 has less height and less reach compared to the 1065A on the Kubota, so the capacity at max height isn't an apples to apples comparison.
I would still choose an MX6000HSTC over a Kioti NX6010CH, particularly given the insignificant 2% premium of the Kubota that gets you a bigger engine among other things.
