B6200 Three Point Issues
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
The pressure specification is 2060 PSI so you are way under. Sonething is out of spec.
With the gauge connected that way we cant tell if the problem is the pump, tractor relief valve, or loader relief valve. If you disconnect the hose and connect the gauge directly to the end of the hose you will ekiminate the loader valve. Start the tractor and you should immediatly see high pressure. Do not rum the engine any lomger than it tskes to get a pressure reading.
Hooked it up the way you described and the tractor doesn’t want to turn over. - cranks slow and feels to me like it’s deadheading.
6,952
I
It is "deadheading" into the relief valve - thats the whole point. Are you using the decompress when starting?
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Yes
I
I tied that. Got a few more rotations but wouldn’t turn over. Don’t want to damage anything so I’m going easy. Pressure did jump to around 1750 psi. While cranking.
6,952
Yes
The tractor has a relief built into the outlet block so you wont damage anything with that hookup.
If you are already getting higher pressure just cranking sounds like at a munimum the loader relief is set too low. Still be nice to get a good solid reading with your current hookup and the tractor running.
There is a selector lever on the hydraulic outlet block. If you move it to the "no implement" position you wont be deadheading into the gauge and the tractor should crank better and start but you will probably get oil out the open port on the loader valve. If you can plug that port and start the tractor you can then move the seIector back to the implement position and get a good pressure reading. Dont run it long with the pump deadheaded.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
My PB has a quick connect. I was able to hook up to there and this is what I got at full rpm’s
6,952
You still have the inlet relief in the loader valve in the circuit sobyou are getting the same pressure as you got im your initisl hookup..
Snce you have quick connects on the loader valve hoses disconnect both hoses and connect the gauge to the supply hose coming from the outlet block. Now move the selector valve to the "no loader" position, start the engine, and then move the briefly move selector back to the loader position to get a pressure reading. That os the max pressure the tractor can produce and should be 2060 PSI.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Ok the. Here it is.
6,952
Ok the. Here it is.
Pressure is still 300+ PSI under specification. Looka like the pump or main system relief need to be investigated. Not real easy to test the pump directly so next thimg I would do is add some shims to the relief valve and run that test again. If pressure comes up the relief setting was low. If pressure does not come up either the relief is leaking or the pump is pretty weak.
Here is the parts r iahram for the putlet. Items 200 and 210 are the adjusting shims.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
2,916
@Ripp
There are illustrated parts lists available on Messicks or KubotaUSA dot com
You can search for your tractor model or the implement model number and find pic similar to what @TheOldHokie posted
I don’t think I have ever searched for the figure number but you might be able to look for them. They are listed in the left area when you click on the area of the tractor that you want to see.
6,952
The one on the fel valve?
Not the loader valve - we eliminated it with the last test. Bump the relief in the tractor,'s outlet block. My apologies- I thought I posted the diagram earlier. Adjustment shims are items 220 and 210.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Gotcha.
So block pressure was 1850- not terrible
Fel was 1500 ish.. though that’s prob not an accurate reading.
All those parts in the relief valve; are they sleeved? could the spring also be worn out?
So just to refresh. The 3pt can’t hold weight. Even my own 180 lbs. with it lifted I can stand on it and it will slowly fall. Specs say rear lift at ends should be 1000lbs.
So just to
6,952
Gotcha.
So just to
Relief valve is just a spring and poppet. Spring could be weak or popper might not be sealing in seat. Pretty easy to disassembel and inspect. Like I said I would add a cpuple shims and retest to see ig the pressure comes up.
None of that has anything to do with 3pt leakdown.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Three Point leak down:
Is this the relief for the three point;
6,952
The main "relief" valve is located in the outlet block up front. I did not check my WSM but I believe that is the safety (port) relief valve for the cylinder. It's a possible source of your leak down but my first guess would be the piston seal followed by drifting control valve linkage.
If you raise the 3pt and hold the lever in the up position does the 3pt still leak down??
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Thanks;
I can hear hydro whistling/hissing out when I'm standing on it and it's falling..
