Kubota BX 25 Want to add a thumb to BT601 Backhoe, Looking for advice.
5,172
5,682
really F1765, ? , you can tell what grade steel is under the powder coat ??
I spent almost 12 years designing,building spectrometers to analyze steel and could never tell by looking .
At $138 it's a bargain as there isn't a lot of stress on the thumb when holding objects.
Joe.G
BX25 W/601
Oct 13, 2024
73
NY
Green that is what I am thinking Is not going to have a ton of stress for what this machine can do. I have no problem spending more if need be.
GibbyESS9
2020 Bx23s,BX2672 plow, Titan Forks, Land Pride 48” BB, FEL, Bestco Flail mower
Sep 30, 2020
96
126
Blue Point NY / Newfoundland PA
I dont have a BX25 but I do have a manual thumb on my BX23S. Had it installed when I bought the tractor. I use it way more than I thought I would. Ripping small weed/trees out of the ground, Picking up logs to cut firewood like a gentleman.
My neighbor up the hill is much older than me and just installed one on his TYM after thinking about it for years. He LOVES it. I would go for it.
Cheers
Jim
yorkies77
Kubota BX23S
Jun 7, 2020
78
61
Idaho
BXexpanded has one they make that is more expensive $369.00. It's made here not in China, I have bought several items from them and they are all high quality. You get what you pay for.
5,172
OntheRidge
Nov 1, 2020
406
471
I have a hydraulic thumb on my L47, love it. The one in the link you provided looks too short to be useful. Good Luck!
Joe.G
BX25 W/601
Oct 13, 2024
73
NY
on the Ridge I did notice that it appears to be shorter. How do I add a Hydraulic thumb?
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
About 4 or 5 years ago I spent a lot of time researching bolt-on thumbs for my 601. The only one that seemed to have consistently good reviews was the BXExpanded.
All of the Amazon ones had plenty of people complaining about one of two things:
  1. Didn't fit. (Some returned them, some modified them.)
  2. If it fit, the thumb slipped under load, and they could not get it to stay in place.
I would like a thumb, too, but I don't like the odds on the Amazon junk, and can't justify the price of the BXExpanded model.
That's partly because I can't find any info on how much I can expect to be able to lift with it. I'm looking at it primarily for lifting big rounds to the splitter.
BXHoosier
BX24
Jan 21, 2018
492
574
Indiana
I had one of the cheap universal fit (Titan) manual thumbs on my BX24 for a while. It took quite a bit of modification to make it fit, clear the bucket curl cylinder, and stop it from sliding on the stick. I got tired of fighting with it and ended up making a hydraulic thumb.
5,682
hmm, so order it, get it, use/abuse it for 25 days, then return it...get money back from Amazon......
it may work very, very well for the OP's actual use
Mark_BX25D
Bx25D
Jul 19, 2020
1,781
1,301
It took quite a bit of modification to ... stop it from sliding on the stick.
Got to thinking about this sliding problem after I posted, then saw your post.
I think I may have solved it in my head. Welding it in place is obvious, but some of us might want to be able to remove it.
So, bolt it in place, do some work with it to make sure it's where you want it. Once that is finalized, weld on some stops to keep it in place. Some 5/16" bar stock cut to an appropriate length should do it. Tack it in place, remove the thumb assembly, then weld it down. Repaint as needed. Then replace the thumb assembly and there you go - no more sliding.
This is absolutely brilliant and works perfectly in my head. :ROFLMAO:
What am I missing here?
BXHoosier
BX24
Jan 21, 2018
492
574
Indiana
I had thought about welding some stops onto the stick as well. It would definitely have fixed the sliding issue.
The modifications I made to the thumb were posted here.
5,172
Joe.G
BX25 W/601
Oct 13, 2024
73
NY
OX looks like a good option, AM I able to use the Hydraulics from my machine or do I need to add something?
Joe.G
BX25 W/601
Oct 13, 2024
73
NY
I'll have to research adding an extra valve to see what that involves, Any good links to doing this?
Thank you
5,236
I'll have to research adding an extra st rk?wotobwant itquestion is what that involves, Any good links to doing this?
Thank you
The topic has been discussed numerous times. Not hard to do The biggest question is how to you want it to work?
  1. Manual lever added along side or nearby the OEM set?
  2. Electric pushbutton on an existing lever?
  3. Foot pedal?
Cost starts around $300 for a manual valve and hoses.
3,241
1,852
Thank you
If you do a search on TheOldHokie's previous posts, you'll uncover a wealth of information regarding your question, and all things regarding tractor hydraulics.
