L3901 PTO lever not working...
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
110
46
Fort Calhoun, NE, USA
I push the clutch in and move my PTO lever to run and slowly release clutch and pto spins up. However when I finish mowing the lever is returned to stop with clutch in and on clutch release the pto starts to engage. I can fiddle with it and wiggle it, and eventually can get it to not engage. Then when I put the brake on and try to get off the tractor stops and won't start again unless I hold PTO switch against contact. Anyway to tighten this or adjust this to work properly? Safety issue!
ayak
L3301 HST
Feb 16, 2018
704
1,004
WV
There’s a section in the WSM that covers the adjustment, but also make sure there isn’t a bunch of debris interfering with the spring action at the other end of the PTO lever. I have to blow mine out from time to time.
3,295
1,707
This kit will fix you right up, it removes the coil spring from around the shaft and replaces it with a stronger return spring that connects to the bottom of the control shaft lever.
KUBOTA TSB-2023-028-E-R1
FIX AS FAIL EXTENSION: L-Series; PTO Lever Does Not Return to Neutral
Models covered: L2501HST, L2800HST, L3200HST, L3400HST, L3700HST, L3800HST, L3301HST, L3901HST
L2501 serial: 50001 to D7056
L2800HST, L3200HST, L3400HST, L3700HST, L3800HST L3301HST, L3901HST: ALL UNITS
Issue: The PTO lever may become stuck and not return to neutral.
Solution: Model Serial Numbers All L3301HST, L3901HST
If the PTO lever is stuck and does not return to neutral, install the LEVER, KIT (S-PTO) per instructions.
Note: If the PTO cable is damaged, replace the PTO cable with the appropriate cable listed in K-Pad for your model.
PART NUMBER for lever kit: TC550-24940
5 Years from retail date (for this specific failure only)
Parts in this kit:
5,504
2,211
squirt some lube on the spring. Drench it. WD40, doesn't matter. Then work the lever back & forth a few times with the engine OFF. It should free right up.
ayak
L3301 HST
Feb 16, 2018
704
1,004
WV
That update kits looks nice, just hoping there’s a way to get it done without taking both rear tires off.
I’ll keep cleaning out debris around the spring and keep it oiled up until that doesn’t work anymore.
