BX throttle handle knob keeps falling off.
pgmrdan
BX2380, L3902HST, Massey Harris Pony, Ford 3000, Bobcat 751 skid steer
Aug 16, 2017
201
80
It just slides off and on. Will gluing it on cause a problem later if certain repairs are needed? That thing fell off again this morning. Eventually I'm going to loose it.
Got a better fix?
I drove an L2502 yesterday and saw that the throttle handle knob has a threaded insert and jam nut.
2,581
So - two ways to fix this problem
1) epoxy it back on and ain't no way it comes off again - and yes it will be a PITA to get off later.
2) Wrap some golf grip tape around it ( I bet you know someone that regrips clubs) wrap it a couple of times, take a little dap of lighter fluid and place on the sticky tape - and slide the knob on and twist where you want it to go. It will stay damn near forever - it can be taken off at a latter time too.
pgmrdan
Aug 16, 2017
201
80
I looked inside the hollow of the knob. Are those some teeth in there???
I tried lightly tapping it on the throttle handle using a hammer. It may have bitten in much better.
Is that the correct thing to do?
John T
2017 BX23S
May 5, 2017
863
343
under a rock
I vaguely remember mine doing the same thing.... I think I shot some Cyanoacrylate into it and put it back together....
haven't had a prob. since.
5,422
Mine has been a little loose for 11 years. Lost it once in the woods but found it.
I live with it. If I ever need to pull it off, makes it easier….
Mark_BX25D
Bx25D
Jul 19, 2020
1,788
1,301
Yep. Superglue can be dissolved with acetone, so if you ever need to get it apart, that's the ticket.
pgmrdan
Aug 16, 2017
201
80
Thanks guys!
William1
BX25D
Jul 28, 2015
1,124
315
Richmond, Virginia
A solvent that will weaken the plastic (like PVC cleaner before the purple stuff), wiped around the inside then put the knob on and rap lightly will work too.,
