Where to keep a walking cane on a tractor?
pgmrdan
BX2380, L3902HST, Massey Harris Pony, Ford 3000, Bobcat 751 skid steer
Aug 16, 2017
202
88
Any ideal places or tips? I also need my trekking poles occasionally but they telescope down to a reasonable length.
Thanks.
2,367
I think something like this would work
If you have a ROPS you could mount it on that, or a tower on the FEl. You might be able to mount it in front of the steering wheel area.
There are many different styles of this but this one is removable and will not leave any damage.
GrumpyFarmer
4,253
A wise member of the forum gave me a good hack using the cross tube of the loader for shovels and rakes etc…I suppose I should pay it forward 🙄. It may not be at your hand from the operator station but if you can climb down and hold loader frame until you get to cross tube maybe that would work?
pgmrdan
Aug 16, 2017
202
88
Wow! Two replies with two excellent suggestions.
Thanks guys!
5,792
'ideal' place ?
whatever side you always get on/off ( left ?)
mount to loader uprights or whatever is 'there'.
cut a plastic pipe 2/3 length of the cane. be sure water can exit...
that way it's EASY to get to
Flintknapper
L2350DT
May 3, 2022
1,972
2,500
Deep East Texas
It absolutely would work! First thing that came to my mind as well.
They can be fender mounted also (or other places). I use them hold a chain hook on my tractor.
Flintknapper
L2350DT
May 3, 2022
1,972
2,500
Deep East Texas
Why did you want a chain hook on your tractor?
I have chains stored in the round tube of the FEL. They completely fill the available space (one side to the other).
You can't push all that chain into that space by hand. So the 'chain hook' allows me push (or pull it).
I didn't want a 'chain bucket' on my compact tractor.
Survivor
L2501
Jun 8, 2025
46
41
I hook the crook over the steel brace that the cheap little factory toolbox sits on, right at the left hand side of the box. The rest sits right down along the inside of the fender outboard of the L-M-H gear range selector. I don't have the "auto cruise" on my tractor so that slot is available for the shaft of the cane.
4,302
Hummm now I need some ideas where and how to store a mass accelerator, for easy access !
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
812
715
E.
I slide a piece of foam pipe wrap around mine to stop the rattle and just drop the cane between the seat and the fender /side window. After work I just pop the foam off but I am not getting on/off at a high frequency.
Clevus
Ko Buddha
Oct 23, 2021
77
121
NW Michigan
I drop my cane behind the seat between the seat back and ROP.
It sit on the fenders and does goe anywhere.
Smokeydog
Jun 2, 2020
757
728
knoxville, Tennessee
Have 5” and 6” square steel tubing mounted vertically for chains, chainsaw, long handle tools mounted vertically on tractors.
Used one of these to keep snake grabber tool on the four wheeler handy. Not for snakes but to pick limbs and rocks out of the driveway without having to dismount. Impressed how securely it holds yet allows easy deployment.
