B6200 Three Point Issues
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Hello All-
Yesterday I was skidding logs and had an issue with the hitch collapsing and not maintaining a set hight under weight. Not sure if the log I was too much. Wouldn’t have thought so.. however. I switch the lever on my block to bypass the fel and no real difference . I had the rpms up to operating speed- stood on the hitch and it went down. Now- I weigh 180 and it should hold me. I push the rpm’s up a little higher (3k) and it held my weight.
the control lever is sloppy; need to replace the bushing- not sure if that’s the main cause though. TIA
6,985
Hello All-
First off moving the lever on the outlet block does not byass the loader valve and confuses things. If you want to bypass the loader valve you.must plug the two outlets AND move the lever.
Put the lever back om the loader position and recheck the 3pt. If its still weak I.would break out a pressure gaugec and start with a couple simple pressure checks .
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
It's been suggested that I have a bad lift piston O ring. Parts 100 and 110. I'm assuming its all under the cylinder cover?
N3BP
Sep 20, 2016
510
239
Lebanon, PA
Tighten up the slop on your control lever. Should be a 10mm nut. If the lever isn't keyed and your slop is excessive, maybe the unit isn't responding?
7,305
I don’t have the tools or the experience to do that.
I don't want to speak out of school - - but I'm betting Dan can talk you through it if he's inclined and you're willing to learn a few things.
I don't have the tools nor experience either, but I've seen Dan walk folks through this kind of thing many times.
Being recently retired, I have gauges and some fittings needed to do such things on my Wish List. Not a lot of $$ needed to accomplish that. $$ well spent to diagnose problems versus throwing parts at it.
Dan is very savvy with hydraulics, and his instructional aptitude is very good.
6,985
You can buy a pressure gauge for $10 and testing is simple. If you are going to work on the tractor hydraulics a pressure gauge is essential test equipment.
First thing to do once you have the gsuge is disconnect the P hose on the loader valve and connect it to the gauge. Start the engine and read the pressure. Should be roughly 2000 PSI. If its not there is something wrong with the supply.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Thinking about trying that. Lever is sloppy. Was looking into replacement parts.
"P Hose" meaning the supply from the pump?
6,985
Yes. That test will give you a baseline number for how much pressure the pump can actually deliver.
You can also use a bungee or piece of string to prevent the 3pt lever from drifting down. Its not a fix but helpful in terms of identifying internal leakage in the 3pt cylinder.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Filter?
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Got the gauge. Just want to confirm the P hose. I was thinking the supply line coming off the block would work..
6,985
Either this is bad or I didn’t do it right…
You did good and got it 99% right. You are one small step short of getting your measurement.
The reason the pressure is showing close to zero is because you are teed into the supply line. The flow is going straight through the open center of the loader valve and back to tank so very little pressure is developed in the circuit. Thats how an open center valve works.
Move the loader valve to any position other than float and hold it there until the cylinder stalls. That shuts off the through flow and as soon as the cylinder stalls the pump will be pumping into a dead end and pressure will spike to max.
Ripp
B6200HST
Mar 6, 2023
30
Pennsylvania
Makes sense. I did that and pressure maxed out at 1500 at full rpm
6,985
The pressure specification is 2060 PSI so you are way under. Sonething is out of spec.
With the gauge connected that way we cant tell if the problem is the pump, tractor relief valve, or loader relief valve. If you disconnect the hose and connect the gauge directly to the end of the hose you will ekiminate the loader valve. Start the tractor and you should immediatly see high pressure. Do not rum the engine any lomger than it tskes to get a pressure reading.
