WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
Central Wisconsin where I'm at was 86 °F and 100% humidity this past weekend, even the mosquitos were sweating. In fact, it was so hot the mosquitoes had to walk to their victims.
Cut and chipped "the little stuff" on a windfall. (more pictures in this OTT post)
Oh, also made cookies.
MotoBBQ
L3902HST w/ LA526 loader; rotary cutter; box blade
Jun 26, 2023
54
324
53
MN
I have a very similar setup using pallets for compost station. It’s not uncommon to push/stab/lift the pallets when turning the compost with forks. If those are attached to that fence behind it could damage your fence if not real careful. Good luck.
Thanks, I used t-posts independent of the white fence you see behind it. I didn't think of using pallet forks to turn it either, planned on using the bucket. Do the forks work better?
GrumpyFarmer
5,213
I think depends on your process. I use my forks to fluff/aerate…couple times per week when heating up good. I think debris forks or even bale spears would work to fluff and let some air in. Then when I move from bay to bay is when I use the bucket to scoop and transfer. I catch the pallet framework most often with the bucket when scooping, especially the last little bit up against the back pallet.
RMS
Sep 26, 2021
312
673
Buckfield Maine
Cut 6 birch trees that were either bent over from last winter or were going to probably go this winter. Left the brush piles for when I get the grapple in a few weeks. I have probably another dozen trees to go. Next week is supposed to be on the mid 60s so it will be a real nice week for outdoor work.
Reactions: 7 users
3,934
2,435
Almost finished the third function re-pipe. I have to finish a bracket/clamp to support the lower end of the hard lines, then test it.
Reactions: 10 users
3,934
2,435
Very neatly done job!
Your L35 looks to deserve a complete paint job.
They don't build new ones anymore!
Thanks.
Yes, Katy led a hard life in her former surroundings. I'm trying to take care of her, but I don't think a paint job is in her future.
Moose7060
Oct 14, 2023
827
2,243
bc
Chain harrowed 2 acres of pasture today. More to do another day. The shackle on the M7060 drawbar didn't fit the 3902 so ran to town first to get a smaller shackle. Stopped at local Kubota dealer on the way home and ordered a 65 gallon boom sprayer. Won't arrive in time for fall spraying unfortunately.
This small mulie buck has been hanging around the tree stand. Think he forgot to grow something.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,977
Near Lancaster, PA, USA
Cleanup, cleanup. Not the tractor. There's an area where I planted pine trees many years ago to screen my shed. Spent two days so far and there's another day to go. Since 1990 the trees grew very large and have concealed some of my "treasures" - various steel, pipes, etc. Trimmed and hauled numerous loads of dead inner branches, pine needles and cones, and junk. Put the brush forks on and moved subsoiler, RFM, landscape rake, rear blade and other stuff to remove the vegetation that took over that area. Never thought I'd live long enough to get around to this task.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,732
4,563
PEI Canada
I had 50 gallons of water left in a second tote so used the forks with a rachet strap to drain it for the winter. Fueled and greased it then called it a day.
I have other projects to do but the ground is too dry for transplanting some larger trees. I tried a posthole last weekend it took a few attempts to get the powder out of the hole.
7,341
Had tractor running for just a few minutes. Temperature gauge reads HOT.
Had this issue before. Pull back to garage, take wire off sending unit, wipe off with towel and apply a little dielectric grease.
No picture, but read in lower half of readout. Wasn’t even up to operating temperature yet, let alone anywhere near HOT.
trevoroni
B6000
May 24, 2023
205
254
No picture again... But used the mighty B6000 to backfill a couple of 4ft deep holes dug by my dad's backhoe at my brother's house.
He's getting upgraded electrical panels in his garage and barn so he needed new grounding plates.
No more glass tube fuses!
5,188
grounding "plates"?
chim
Jan 19, 2013
3,278
2,977
grounding "plates"?
Few different methods of grounding. One is to bury plates (lots of surface area). Then there's Ufer grounds where the electrode is concrete encased. More common driven ground rods (sometimes single, sometimes multiple). Rings of buried bare cable with or without rods, etc.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
I spent some time yesterday cleaning out the area where I need to install a French drain. On the town's topo map it shows a tributary for a nearby river starting right here. The area is muddy most of the year and the dogs apparently love to go there.
It's a swale dropping about 4 feet before it starts rising again. I used the stump bucket and regular bucket to get in there and clean it up a bit. As you can see there is no lack of rocks here. I had to drop a yard of fill so I could get down there (and out). Not a big project - about 50' long but when through the dogs will be able to go up on the hill without being caked in mud.
Reactions: 6 users
5,188
A nearly pure white yellow Lab in the mud?
That almost never happens! :ROFLMAO:
Old_Paint
Dec 5, 2020
2,047
2,334
AL
Got started with our winter garden this morning. The raised beds needed a little makeup soil to get them back to full level, so I got a bucketful from the compost heap and blended it by hand. I figured out real fast that a shovel that my ex-SIL broke when he borrowed it was the perfect length for working in raised beds that are nearly waist high to me. Used the little push plow to set up a ground level bed for the broccoli, sprouts, and English peas. Has to water the ground bed, but all the raised bed boxes still have plenty moisture. Shot the 13-13-13 to all of it and hopefully will have a bit of nice greens in a few weeks.
Got cabbage, lettuce, radish, carrots, and spring onion in the two large beds on the right. Gonna overhaul the strawberry bed and top up the large bed on the lower right tomorrow. Rather warm September morning with lunchtime temperatures at 93 with a feels-like temperature of 99. Don’t have the big water oak shading these anymore, so hoping for some improvement in performance. We usually have pretty good broccoli, but the sprouts never seem to mature before cabbage worms get them in the spring. English peas are hit/miss. I’m not putting the trellis back up until I see peas sprouting.
Reactions: 7 users
GrumpyFarmer
5,213
Good day.
The gardens looks good 👍
The garden box’s on the right in the pic (black plastic boxes with lid raised)…are those homemade or purchased? (If purchased what / where from?).
Thanks in advance.
7,007
The weekend started off well on Saturday evening. Cleared some atv "trails" thru the no-mans land swamp area of my property for my wife's "Lil Sister" to ride around on.
Sunday, whacked 3 more dead trees. Here's a dead/dying pin oak. I now have quite a bit of free firewood stacked up by the road to give away. I'm guessing the pile of logs is in the neighborhood of 4-5 cords.
Then, while parking the tractor for some lunch...I came in a bit too hot!
The tractor bucket opened my garage like a can opener. GRRRR :mad:
  • Sad
Reactions: 13 users
