B7200 ROPS
wally2q
B7200
Sep 15, 2024
20
ontario, canada
Hi everyone! New guy here.
Been a long time "green tractor" owner, but now I am also an "orange tractor" owner.
Looking to add a ROPS to my new-to-me B7200 HST-D
OEM from kubota, here in canada, is >$1,100
Anyone know of any universal kits out there that may work?
cheers!!
10,703
There are no other universal kits known to fit.
And I highly suspect that you can get an OEM ROPS for it.
They have been long Obsolete.
barts
4wd B5100 w/ FEL, box blade, JD110 TLB, WC68 chipper, log arch, brush mower.
Feb 10, 2015
125
115
Lopez Island, WA
Kubota has had a program keeping ROPS in stock for old tractors that never had one as a way of limiting their liability in roll-over accidents. I bought one for my B5100 perhaps a decade ago for less than $300.
2,941
That program has expired in the USA.
I don’t know if Canada ever had the safety program
10,703
Yes long expired program.
Donystoy
Dec 10, 2013
716
356
Binbrook, Ontario
Back in probably the late 1980's I enquired about the availability of oem rops and was told that they were not available in Canada. I ended up making my own including seat belts. I think I had about $100 in steel and an evening's work into it.
wally2q
B7200
Sep 15, 2024
20
ontario, canada
That is awesome!
was that also a B7200?... do you happen to have some general dimensions?... and having made it as you did - and then used it... if you were to make it again, is there anything you would have changed or improved?... dimensions - height... width... choice of material... etc etc?
wally2q
B7200
Sep 15, 2024
20
ontario, canada
one more thing - is that a 3pt hitch Backhoe?... or special install / special subframe install unit?....
what's the make/model of it?....
5,126
Nice job on the build.
Looks almost factory.
I dig those grab handles too.
(and with inflation, you might be able to sell that steel for more than a hundred now) ;) :ROFLMAO:
Donystoy
Dec 10, 2013
716
356
Binbrook, Ontario
I built the subframe a couple of years after I purchased the tractor new. I installed oem power steering at the same time. This frame also brought the hoe six inches closer to the tractor than the 3ph did. The frame is a full box frame which fully "clamp's" the tractor together and reinforces the top of the transmission. I have lots of pictures of this.
wally2q
B7200
Sep 15, 2024
20
ontario, canada
Well that's just awesome and exactly the info I need.
I just bought this b7200 and need to bring it up to the level I need.
Whats the best way for me to bug you to send the pics and info?... here on this thread or via PM?
Prefer this forum - so others may benefit - but up to you.
I have the b7200 now.
1. Need fo add rops
2. Need to add BH
Cheers!
Donystoy
Dec 10, 2013
716
356
Binbrook, Ontario
1. Need fo add rops
2. Need to add BH
Cheers!
wally2q
B7200
Sep 15, 2024
20
ontario, canada
You inspired me to do the same.
Steel cost me about $130.
Took about 8hrs over a span of 2 days, to cut, fabricate, weld, paint and bolt it all together.
I overhauled the tractor as well - fixed a number of minor issues. Added a coolant reservoir tank. Added temp sensor and gauge (with a 3d printed gauge pedestal). Added LED work-lights to rear fenders and top of ROPS. And a Tool box.
It's almost ready - but I decided to add power steering. Still figuring out if I will install the C3 corvette power assist, or a marine IO drive power assist. If you have some insight into this, that will make the installation easier and/or cheap - let me know.
Cheers!
5,126
Cheers!
Nice job man!
I dig the thermos holder too. (y) (y) (y)
Donystoy
Dec 10, 2013
716
356
Binbrook, Ontario
Looking good! Power steering makes all the difference. Fortunately I bought the oem kit shortly after purchasing the tractor when it was still available.
