B7610 Turning off
EdwardsKev
Kubota B7610, Betstco Flail Mower, 5ft HOWSE bush hog
Mar 10, 2023
9
Spartanburg South Carolina
So last weekend I was bush hogging and before I could get back to my truck to get my diesel can, ran out of fuel and the tractor turned off. I got the can and filled it up. Started the tractor and started moving again. I moved about 1 ft and it turned off. Restarted and trying moving again and it almost turned off, but I stopped moving and it started in. No matter what direction I was moving. It did that for a few minutes and then didn't do it again for the rest of the day. Today I took my tractor off the trailer, blew dust and grass of the engine, started it up and went to move and it started doing it again. Thoughts? Anyone had this issue before? TIA
11,304
Does it die suddenly like the key was turned off?
Move the HST pedal back and forth does it try and die when you do that?
Does it bog down?
And if it bogs down, any smoke?
EdwardsKev
Mar 10, 2023
9
Does it bog down?
It does kind of seem like the switch was turned off because if I'm moving forward with the pedal and it starts to die and I let off the pedal to stop it will stay running and it will do that whether it's in going forward or reverse. It does not bog down and it does not normally smoke. It only smokes on the first time I start the engine.
11,304
Seat switch or HST switch issue.
It thinks your not in the seat.
InTheWoods
B7510/FEL, B7100D, ZD18, ASK-R130
Nov 17, 2023
279
231
Indiana
...if I'm moving forward with the pedal and it starts to die and I let off the pedal to stop it will stay running...
To me that sounds like fuel starvation. It starts to die under load, but removing the load allows it to keep running?
Since you report this happened after you ran it out of fuel, I'd look for ways to bleed the fuel system. Not supposed to need it (like my old B7100 does), but still...
A plugged fuel filter also causes this behavior, so that'd be worth a look.
N3BP
Sep 20, 2016
510
239
Lebanon, PA
Makes you wonder if there was an accumulation of debris at the bottom of the fuel tank that got sucked through the hose when the OP ran it dry.....
