Fixing hole in side of block
Status
Not open for further replies.
jaxs
B1750HST
Jun 22, 2023
1,111
835
I think you meant "Joe, its not high heat that cracked your cast iron skillet,"
Or he might have meant "Joe,it's not high heat that will crack your cast iron block."
It's stress from uneven expansion/contraction.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Reflection and observations:
After preheating the cast iron skillet to 400 in the enclosed bbq grill, I ADDITIONALLY hit the cast iron with the acetylene, and I do recall hitting the top part of the cast iron skillet (where the cracks formed) HARD to test the narrative:
"What happens if you hit the cast iron with too much heat?" It will warp
The bottom of th cast iron, I DID NOT hit it as hard with the acetylene, notice the no cracks in the cast iron on the bottom portion, same stress from the cutting wheel
My focus now going away from aiming the flame on the cast iron, aim the flame on the BRONZE because:
That area where the weld held TIGHT after hitting it with hammer, I was aiming the acetylene on the BRONZE, and less so on the cast iron
This was done to test the narrative: "What happens to the bronze if you hit it real hard with the torch?"
The exact sequence I noticed of what the bronze did: First it was a bead circular glob. Then I hit it with the the torch, then it leveled out and melted INTO the cast iron (amazing)
It will turn to flat liquid and bind HARD with the cast iron, which is the goal
Some of yall said it and it is the MOST important factor in getting them to bind:
hit it HARD with the grinding disc EXACTLY where you want the bond, real deep, and have ZERO oil on it including finger oil
Then put the flux on that area and give it a tiny bit of torch to melt it into the cast iron, then
Come in with the bronze rod in the left hand, melt the bronze in that area, then adjust your distance of how you are hitting that bronze with the torch, trying to get it to melt into the cast iron,
you (I) are not aiming the flame on the cast iron, but rather the bronze, trying to give it the RIGHT temperature to bind the cast iron, BUT not too hot to damage the cast iron
Those are reflections for anyone who wants details of observations
Next scheduled experiment: tomorrow morning
Hit everything HARD with grinding wheel and start fresh,
(new step I am adding) grind a nice round even circle into the cast iron where I want the weld to hold, you cant use pens or sharpies because that is an oil, this is the guide to make the circle more perfect
put the skillet in the BBQ grill, preheat to 400 for 15 minutes, use a precise way to glob the flux into your outline, then hit that with some torch until the flux bubbles a bit, THEN
come in with the left hand with the bronze rod, get it melting along your outline, get it hot enough to be liquified but not too hot to damage the cast iron
Goal: build a nice round circle of bronze that holds TIGHT to the cast iron and is not filled with gaps WITHOUT damaging the cast iron
5,188
Beginning to look a bit like "pallets in the field" post count.
trevoroni
B6000
May 24, 2023
205
254
The heating of the cast is not to get it to melt anything it gets it up to a temp that makes the added heat needed to get the bronze to flow less of a shock for the cast.
The reason the pan broke the way it did is because you introduced uneven stresses on it when you cut it.
One much more achievable simple result can be achieved by crafting a patch for the block out of mild steel and then use an epoxy like JB weld to bond the two together.
I fact you would need any thing else other than epoxy to fill the hole, because you could dam the back of the hole with tape.
You wouldn't be introducing any more stress to the block and you will be able to achieve a permanent patch, that will out live you or I.
If this was my project I would do just that and I know how to weld, and I know how hard it is to weld cast.
This is what I was thinking as well.
I repaired a hole in a Honda ATC 90 when the chain snapped and broke a hole in the case.
It's held up for the past 11 years now with no issues.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Whoever said those little tanks are useless was right
Hit cast iron with grinding wheel
Used a cutting disc as outline to trace perfect circle
Used grinding wheel to strip away some cast iron
put skillet in BBQ grill
After 15 minutes, I sprinkled flux along the outline, flux bubbled
Soon as I started the weld, tanks ran out! Bummer
Had to drive for couple hours, landed a deal on massive tanks that have gas in them
Came with both tips, notice how this cutting torch does not have those holes inward like that other one
My theories didn't work: bronze only beading and won't flatten into the groove, did not stick
Hit it again with grinding wheel
Tried again with much more heat, propane and acetylene
Still same problem, Bronze not flattening, only beading
Ran out of bronze rod
The problem: I cannot the bronze to lay flat, all it wants to do is stick to the rod and bead, it will not lay flat, no matter if I hit the cast iron hard with acetylene then come in with the bronze rod, or
if I focus the acetylene on the bronze, still the same exact issue, bronze will not liquify and flatten
No matter what I tried, I cannot get the bronze to sit in the groove
Next experiment: give the cast iron skillet even more propane heat in the bbq grill (450 fahrenheit), use the rods with flux in them instead of separate
Now: go watch videos of how people lay the bronze flat and see if I can improve my method
5,164
Now that you have 2 larger tanks, keep your eyes open for 2 more. That way when one goes empty, you can grab another full one. Then has the empty exchanged for a full tank, and you will always have one in service and one waiting to go into service. I use the small tanks because they ae easy for me to move around, but if the job requires a lot more thermal muscle, I can always break out my large tanks and spares. I used to keep them in the garage, but now keep them in an outside shed. Much safer in the event of a fire. If you have ever seen one of those tanks in a fire you would understand.
5,188
Don't worry, I'm fixing now to get experimenting and will report back
You need to "figure out" that laying the acetylene tank down (when containing acetylene) is a very BAD idea.
jaxs
B1750HST
Jun 22, 2023
1,111
835
While you are at it you need to "figure out" when you ask for advice and some one offers it,don't ignore the advice. Some one with experience said block with hole in side is likly damaged far more serious than having a hole in it. That fact has now been overshadowed by attempts to patch a skillet. After hole is patched you can "figure out" how to line bore using broom handles and a chainsaw.
Reactions: 6 users
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
defeated, I went back and reread all yalls statements
my method was not even close
Watched these clips, generally trying to understand what they are doing and what I am doing wrong
Things I was doing wrong: acetylene flame not even close to being strong enough, bronze melt at 1800, cast iron melt 2200, you need to hit the area hard with acetylene (someone did say you need more flame)
The appearance of what they are doing: they hit an area hard and create a cherry red section, then they come in with the bronze and build up a puddle encompassing the crevices
Those that can weld on cast iron are very talented
Next steps: get more rods from welding shop, try to do what the clips show
11,295
The third video is not brazing it's using muggy weld rod, muggy weld rod is more of a hard silver solder than a brazing rod.
They are expensive, but work well.
I have tons of brazing rod here all different alloys and flux.
I'll see if I have a piece of cast that I can patch up to show how you can run a weld.
But you are going to need a ton of heat to get the block to weld up, and if your real lucky, not crack into the water jacket.
You will also need to pack the block on sand to let it cool slower than in open air, if you don't your very likely to crack out all of the weld.
I'll say it one more time: Epoxy would be a much smarter, safer, and cheaper way to fix that block.
No possibility of doing more damage!
5,188
Unfortunately, repeating your suggestion is unlikely tp be helpful.
Like most of us, I do not think that you completely understand the issue!
Joe,.......just needs to...... "figure it out"!
6,329
I agree with NIW that metal epoxy ( aka JB Weld...) is THE solution for a quick, easy, economical repair.
Can be done in a day and will outlive the next 3 owners.
Have done several small engine blocks as well as gastank for a 58 Austin.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Yes it is amazing how they get it on the cast iron, i.wish I can do that
Yes 100% I agree with you and listening
That will most likely happen
This welding detour is NOT about brazing the block, but rather a lesson in metallurgy for myself and whoever is watching
Even if I patched the block with epoxy, I still cannot move the rebuild forward since there is about $1000 in parts needed, including a press to put in new wrist bushings, all the main bearings, gaskets, and I still have to figure out if
I can use the piston assembly from the engine without the hole in it, transfer that into the engine with the hole
Summary: because there are still big purchases that need to happen before putting the engine back together, there is a welding detour happening while I wait to purchase the rest of the parts
Also, there are about 20 welds that I need to do beside this major one, including a major weld on a hinge that holds a heavy post hole digger
Broken weld on heavy duty post hole digger
I need to figure out how to make metal stick together MORE than I need to rebuild these engines
For $50, I got all kinds of bronze rods of different thicknesses and plain/flux coated, you are looking at 5 pounds for practice
Next scheduled experiment: couple hours
Plan: do what those people are doing in the videos I showed yall, I am willing to eviscerate the cast iron trying to get the bronze to stick
Loaded up on Welding gas and rods, I am good to practice without interruption
Only thing missing is good gloves since I am fixing to turn the flame way up on the acetylene
5,188
The BEST way to "figure out" how to make metal "stick together" is to take the metal to a professional metal "stick together" guy!
3,410
Actually, I think that’s the best way to make sure the metal sticks together.
But it’s not the best way to “figure out” how to make the metal stick together with your own hands.
I think I’ve always been a do it myself guy, but there have been times when I paid somebody else to do it. Not a lot, but that’s happened and it will continue to happen in the future. Actually getting older I think it’s gonna be more now than then. o_O:ROFLMAO:
So I get where Joe’s coming from. He wants to learn something as much as he wants to make something happen. I don’t fault him for this at all. Personally, I think it’s a positive attribute. At least as long as time is on your side…
Sidekick
Jul 29, 2023
1,292
1,887
N.Y,
I think it's best to take a night class at your local BOCES or college for basics for something like welding if you didn't learn them from your dad growing up.
joesmith123
L295DT, BX1500
Mar 18, 2023
296
140
earth
Right? I would have responded if I wasn't repeating myself
Get this detail, I am fixing to give up everything until I can "figure out" how to make metal stick together, everything else on hold
I see it as the closest thing to magic
Zero chance. If people are paid to teach you, they are there by force and cannot teach you anything legally and literally.
We are at one of the greatest schools available to us, this forum. People volunteering information not by force is the ONLY way to learn.
Greenville Jay being able to braze cast iron and him giving his 2 cents is greater than all schools.
Greenville Jay is more talented than all billionaires
I am sure there are others on here that can also braze cast iron and the same narrative applies to them
5,188
BINGO !!!!!
Though Joe prefers to ignore wise suggestions, and apparently believes that HE can reinvent the wheel
Status
