PTO Shaft recommendation
haanzel
L2600DT, G4200 mower
Jul 30, 2014
122
My shaft got bent, I tried straighten it but it won’t slide in all the way without binding. It takes a big hammer to unstick it and I am tired of doing that every time.
So I am in the market for a new PTO shaft. Need splines on both ends. I see Northern has Braber, but the specs say for 16HP max, i need more than that. Maybe it would work? Any recommendations on where to get a shaft ?
woodman55
L6060HSTC, RTV 1100
May 15, 2022
927
721
canada
Your dealer should be able to replace just the tubing in your shaft.
5,235
1,018
If you provide more info on whatever implement the pto shaft came with one of us can point you to where to buy just the shaft. Usually at each end where the shaft enters a casting there is a roll pin to allow the shaft half to come free.
This illustration is of a typical shaft
4,908
re: My shaft got bent,
like Dave says 'WHAT SHAFT ' ??
You list a lot of equipment in your 'profile' and ,well, the shaft might not even be for one of them ! I don't assume anymore....
haanzel
Jul 30, 2014
122
I will look at the shaft closer, it came from a flail mower I bought used years ago.
old and tired
L2800 HST; 2005; R4
biketopia
Feb 15, 2024
137
81
Warrenton VA
I was able to find a shaft on Amazon, and another on surplus center for under $100, cut them to my desired length and rock and roll. When I first got my finish mower, i replaced both tubes because they were bent. I was newer to tractors then and didn't search much and only saw complete shafts for $500 at Tractor Supply and didn't look harder. The replacement shafts cost me $100 shipped, plus I had time in taking it apart and back together, then cutting it down to the right length.
haanzel
Jul 30, 2014
122
Here are some pics, I was using it so couldn’t take it off.
looks like one side says TYM? Or TJM? Or TM? The other side of that shows R-44.
LMK if this is enough and where to get a new shaft. Specifically, it’s the narrower of the 2 (one with grease) that I need as it binds when it goes in further.
4,491
How do you know the inner one is the bent one?
haanzel
Jul 30, 2014
122
I could but if I can replace the tubing I would like to do that as was mentioned above. Getting a new one would be my last option.
2,816
Why "last option"?
Are they prohibitively expensive?
I've never had to replace one.
Smokeydog
Jun 2, 2020
669
623
knoxville, Tennessee
Replaced one last year. 47HP. $135. Surprised of the quality. Having proper safety shielding important. Properly adjusted slip clutch saves wear on driveline.
4,491
He does not even need a slip clutch. Complete new 35HP shaft is probably close to the cost of one repair tube.
haanzel
Jul 30, 2014
122
Thanks, I had seen some that were $350-$500 which is why I wanted to try to fix what I had. Both of the ones above would do, just need to figure out length.
WRT the slip clutch, I’ve never had one, but I think it works when something gets caught in an implement, like a mower, that the clutch will slip instead of damaging the brush hog. Is that correct?
Smokeydog
Jun 2, 2020
669
623
Yes. My flail, rotary cutters, tree cutter, rototillers all have slip clutches.
They do require some knowledge and adjustments. New shafts come with some instructions. Not best to store outside in the weather as the clutch material can rust to the plates.
haanzel
Jul 30, 2014
122
Thanks, I should probably get the slip clutch one then, I mainly use it for my flail or brush cutter.
haanzel
Jul 30, 2014
122
Another question on pto shafts- I have another (longer) shaft that has a collar end with 2 ball bearings that push up/down when the collar is pressed/released. The bearings are dirty and rusty. What is the best way to clean these? I can’t seem to find how to take apart the collar either. The shaft is good otherwise.
