I have a 2650 with cab and Argi tires. I have the front mount snowblower and plow attachments. Would a counterweight box filled with rocks or gravel be better than chains? Thank you
Most wealthy Connecticut folks have "very long" paved driveways!I have an older Kubota counterweight box that says the BX should have 300# in it. I snowblow with over 600# and turf tires and have never encountered a problem with either my BX22 or BX23S machines. I would never use chains because of the bumpy ride unless working on a gravel driveway. My driveway is very long and paved. I suggest that you consider retiring your Ag tires for the winter and use turfs.
There is no yes or no answer to your question. Either will help.I have a 2650 with cab and Argi tires. I have the front mount snowblower and plow attachments. Would a counterweight box filled with rocks or gravel be better than chains? Thank you
