Slip Clutch assy for LandPride 1860 rotary cutter
pinkerpv
3800, rtv1140CPX
Jul 13, 2016
35
MADISON, ALABAMA, USA
I have an 1860 LandPride rotary cutter with the slip clutch assy for the power takeoff drive shaft. Over the years the assy has worn and now the clutch assy wobbles and causes the drive shaft to wobble. I want to buy just the part of the assy that is worn but it costs $350+. A new clutch assy is $450; however I have found an aftermarket assy that should fit for $200+. The part i need is a solid cast part machined for the gearbox shaft. It has a hole thru it for the bolt to hold the assy to the shaft.
My question is does anyone know of a salvage yard for tractors and specifically Landpride equipment. I have found a few on the webb but no parts for me.
JimmyJazz
1,273
805
Pittsburgh, Pa
At the risk of stating the obvious have you checked Amazon? There are many PTO slip clutch assemblies being offered at the sub $100 prices point. Good luck.
Mitjam
Jan 14, 2013
348
420
Edmonton, Alberta, Canada
Hi there like Jimmyjazz said there are quite a bit of options without going to dealer. Something like the pics I uploaded is what you’re looking for. As long as you buy a cat 1 should be ok. It will either be attached from the u joint with a roll pin or a spring assisted pin. If there is wobble there is a chance the u joint may be failing. Sometimes you can find a whole pto assembly cheaper then trying to replace each u joint and clutch assembly. Good luck
pinkerpv
3800, rtv1140CPX
Jul 13, 2016
35
Already checked the webb including Amazon. Already found a replacement for $200+ which beats the $400+ from Landpride. looking for a salvage yard to get the part even cheaper.
