Electrical - Wiring Diagrams
Hydro
ZD21
Sep 3, 2024
Southern Indiana
Needing a wiring diagram for a B2630 -- mainly the part for the OPC -- blowing the 5 amp fuse randomly
EDIT
after searching I found the diagram here --editing to add the diagram to the wiring section
eschap
lots of kubota ag equipment
Jan 21, 2024
Chelan Washington
I discovered the hard wY that the wsm fir new l4060 etc has the wrong hst setting procedure under test preparation. The error is "setting the range seleter to nuetral between L and M" the correct one is select nuetral between Mand H.
Now the process will begin. And fyi contrary to some "kubota does not require a laptop to service or program these settings, it's all done through the display
3,137
L295 wiring diagram
L305 wiring diagram
L345 wiring diagram
amberwavesofgrain
Kubota L3240DT
Nov 15, 2024
LaSalle
Can anyone share the wiring diagram for L3240? More specifically the path for the stop solenoid. I have no power at the key stop fuse posts and no power at the stop solenoid when in ACC— tractor will slowly crank but will not turn over.
11,211
There are mutiple wiring diagrams depending on which Sub Model (DT, HST, GST, F) you've got, The WSM has what you need.
primetime
Hello, where can I find a wiring diagram for a Kubota 588I-G 688 888 758 or 988?
Basically I just need the wiring schematic for the multi switch which looks to be part number 5T057-12242, 5T057-42242, 5T05712242, 5T05742242, or 5T057-12242 which comes in any of those models.
I was not able to find it here:
Index of Kubotabooks/Tractor Owners Manuals/
11,211
Do you have this unit?
Or just looking to use the switch for this unit?
primetime
11,211
I'm just looking for the wiring schematic for one of the models listed as they all contain the same style multi headlamp/turn signal switch. Essentially looking for something like this but for a Kubota 588I-G 688 888, 758 or 988.
You didn't answer any of my questions?
A WSM for any of those models is very unlikely to exist as it's not a normal import to the US.
It is what they call grey market and Kubota USA offer no support for them.
If your just trying to use the switch for a BX80 series replacement or some other application, test it with a meter.
primetime
I'm trying to use the switch for another application non tractor related. I'll check it with a meter. Thanks for letting me know about the import situation.
Annjen22
Kubota M7580
Dec 21, 2024
Cleveland, UT
I am looking for a wiring schematics for a M7580. The tractor will not move, and the rear implement will not raise, and the pto blows the fuse. The front bucket works. Thanks.
11,211
You need the WSM
Annjen22
Kubota M7580
Dec 21, 2024
Cleveland, UT
11,211
The service manual doesn’t have the wiring diagram.
The WSM will have the wiring diagram in it.
If you bought that WSM and it didn't have the wiring diagram in it then you need to contact the seller for a refund as it's not complete.
