Play in HST pedal worn bushing on trans
Speedybon
68
23
Arroyo Grande
I have B-7800 that has play in the forward/reverse pedal. What I found was a worn bushing mounted lever mounted way inside on the transmission I think this looks like a problem. What it does is make the forward/reverse pedal have travel in the neutral position. The year is a 1993 HST B-7800. I have parts manuel and a owners manuel so I am trying to find what I need. Any help would be apprieated
5,726
Curious was I....Probably 2 pcs of #020, bushing $5 each ?? Maybe #070, while your at it ?? Check for slop at #100-120
Speedybon
68
23
Arroyo Grande
Speedybon
68
23
Arroyo Grande
Well I found the concern it is the Neutral holder. Its is the roller that failed, it looks no fun. I hope the roller is the new up grade.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
681
155
Rising Sun, MD
I had to replace THAT bearing on my B2410 a few years back. The bearing was toast. even a couple of "balls" had fallen out. It is a quick and simple swap out ..... but getting to it is a BIt%^$ !!!
Butch
Sep 10, 2009
681
155
Rising Sun, MD
Will my 2003 Kubota B7800 should be repair tomorrow as soon as the bearing gets here from Messicks. It was not the most fun job. Getting the race off was the hardess part. Also looking for my gray Kubota paint was my next job. Here are some pictures.
I should have mentioned the easy way to get the race off... I used a Dremel Tool and a cone grinder to slowly cut it.... took maybe 20 minutes. When it got razor thin ... it just popped apart and I slipped it off with two fingers.
3,229
Here I thought you would have said “Getting to it was a Butch!" 😂
