Belleville washers
5,202
Anybody have the part number for the Belleville washer that go on the mower deck for the blades, there are 2 per spindle and the blades keep coming lose so I thought maybe replacing them might help. Anybody ?
3,035
Not sure - but this might be your number:
K5651-34350 (new number K5651-34352)
https://www.messicks.com/parts/kubota/K5651-34352
check your deck when you go to Messicks
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
471
268
Randolph county N.C.
I suggest making sure you are getting the correct amount of torque on the bolts and that the blades being used are the proper thickness. I had problems with blades loosening when I didn't catch that the Oregon Gator G-5 blades were thinner than the the O.E.M. blades.
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
75
12
3,544
1,974
Perhaps since there are multiple part numbers for the Belville washers depending on the deck, we should find out what model number the deck is before we guess which washers it takes.
