1993ish 2182 with a 60' mowing deck.
I mowed the back yard and the side yard. In the morning started on the front yard and on my second pass the PTO belt broke.
Shut it down and ordered the new belt. Annual service, I pulled the deck removed the belt parts, sharpened the blades and cleaned the tractor top to bottom, got a new fuel filter. I started up and halfway to the garage it cut out. I had run out of fuel. Filled the tank and NO GO. WTH!?!? This tractor runs all the time, starts and goes to work.
I was able to restart but she won't keep running.
Went through the whole fuel system, tank to carb, new filter, pump working, fuel flowing to the carb, checked the spark, good to go.
I was able to get started and run for a good 5 minutes, it then stopped as though it ran out of gas again, but it hasn't.
I will pull the carb in the morning and clean and inspect it.
Could this be the solenoid?
What else? I do this service every season, (not the belt breaking) this has not happened.
