Care to share?I need the serial number of the tractor as it appears from just the picture of the pump it's not the standard M6950.
One thing I have gleaned from the Blue prints it that does not have a normal three point setup.
It actually uses the lower three point arms to sense the weight on the arms and adjust the three point accordingly.
It's quite the elaborate setup.
Bear with us as we get more technical info to help you out.
Have you checked the lower lift arms (where they connect to the tractor) for any heavy wear or bearing issues?
