1 1fishinrogers New member Equipment M6950 Apr 25, 2024 16 1 3 NC Jun 9, 2024 #41 TheOldHokie said: I reread your description of the hot pressure test. Did you run that at engine idle speed? It should be run at 2400 RPM. Dan Click to expand... No 2400 I was referring to hydraulic system I guess it was misleading
TheOldHokie Well-known member Lifetime Member Equipment L3901/LA525, B7200DT/B1630, G2160/RCK60, G2460/RCK60 Apr 6, 2021 7,439 3,657 113 Myersville, MD windyridgefarm.us Jun 9, 2024 #42 1fishinrogers said: No 2400 I was referring to hydraulic system I guess it was misleading Click to expand... OK - then there seems to be a problem with the pump and/or relief valve. As I said inspecting and cleaning tje relief is easy. Do yo know how to plumb and run a pump test? Dan
