2ND PTO drive
buckeyePhilly
B7500 / 48 in rotary cutter
May 30, 2024
PA/OH
I've read several items where owners say their MMM and rotary mower both run together, when in the 960 range. I haven't heard if this is harmful or not. Any input on this??
I have a b7500.
4,475
Curious, I looked at my BX23S manual.(I've never used the PTO.).. has the same setup.. BOTH Mid and Rear PTO can be spinning at the same time !
Now I want to know as well....WHAT operation needs BOTH PTO spinning at the same time !!!
RMS
LX2610HSDC, RCR1260, PFL1242, LX2963, RB1684, WC-68,Flail Mower,Z421
Sep 26, 2021
200
348
Buckfield Maine
When I bought my LX the dealer told me that the only thing he could think of for using both would be a MMM and a pto driven bagger.
4,475
Hay , that's one combination I'd never have thought of ! Thanks.
I don't bag my grass but do pickup 3-4 bags from neighbour, toss on my compost ,dry,fold,reuse his bags around here...
BAP
Dec 31, 2012
2,613
737
Just to avoid the hassle of disconnecting one or the other, if I don't need too.
I thank you are going to find that your B7500 is NOT going to have power enough to run 2 mowers at the same time with any type of performance.
buckeyePhilly
May 30, 2024
PA/OH
The issue isn't that I " want," to run both at the same time. They just do!
I was just trying to find out if it's OK to operate like that.
5,646
Simple answer yes it is designed that way.
More complicated answer, if you demand more torque and HP than the tractor should be putting out, you will break something, and that something is usually the most expensive part on the tractor. :oops: 😟
