I've read several items where owners say their MMM and rotary mower both run together, when in the 960 range. I haven't heard if this is harmful or not. Any input on this??
I have a b7500.
I have a b7500.
Just to avoid the hassle of disconnecting one or the other, if I don't need too.For what purpose?
Ok that didn't really answer the reason why you would ever want to run both at the same time?Just to avoid the hassle of disconnecting one or the other, if I don't need too.
I thank you are going to find that your B7500 is NOT going to have power enough to run 2 mowers at the same time with any type of performance.Just to avoid the hassle of disconnecting one or the other, if I don't need too.
The issue isn't that I " want," to run both at the same time. They just do!I thank you are going to find that your B7500 is NOT going to have power enough to run 2 mowers at the same time with any type of performance.
Simple answer yes it is designed that way.I was just trying to find out if it's OK to operate like that.
