Preventative routine maint
KUBOTA4900
KUBOTA M4900SDC & LA100C LOADER,PALLET FORKS,BRUSH HOG BOX SCRAPER 3PT HITCH
Feb 3, 2013
65
durango colo la plata co
So have a question concerning maintenance i have had my kubota
m4900cs 6 months
it was purchased used it a 2000
i have put 20hr on it since i got it i chk oil , tran hyd fluids regularly
is there more i shud do or start lookin at
when it was delivered it had 2002 hr now its got 2022 all has been good at some point i know i must do more
any info is trully appreciated
thanks tony
freewheel3
Mar 9, 2013
333
34
Alberta
Get a service manual and If you don't know the maintenance history, I'd change all fluids and all filters (Engine oil, Trans/Hyd, Air and Fuel). Also grease all the fittings. After that, just follow the maintenance schedule in the Service manual. You could also check tire pressures and wheel lugs for torque. Checking for any other loose nuts or bolts periodically isn't a bad idea as well.
KUBOTA4900
Feb 3, 2013
65
20 hours in 13 years??????????????
That's the worst thing you can do with any machine.
sorry should hav been more clear i traded in my smaller kubota 6 months ago and i got the 2000 m4900cs i hav owned it approx 6months and hav put 20 hrs on it
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
77
Rocky Face, Georgia
If you don't know the history besides changing the oil and hyd fluid and filters I would drain, flush and refill the cooling system with fresh coolant.
Look at all your fuel lines and coolant hoses for signs of wear and or cracks.
Check your battery cables to insure they are clean and tight.
KUBOTA4900
Feb 3, 2013
65
Well went down to my dealer n spoke with rich my sales guy for the past 15 yr.
He looked up all his records k wait wait he had all past service n 2 repair orders
n also ushured me the 1 owner prior was a very meticulous customer of his
so i kinda skimmed thru them n yes 50-100-150 and all way till he traded it in service and repair all done by the dealer
oh and after seeing them i decided im not havin them do mine wow very hi dollar
the 2 repairs were the left wheel beering repair and the drive line i think it said yoke or something to do with the u-joints and my god need a seperate bank acct set up just for repairs wow
anyway that my investigation report so lets start over guz shud i go ahead and change all fluids just to be safe
i do also greese all my zerts chk all my fluid levals and do basic preventative maint on a daily use schedule
there r times i dont use my kubota for 7-10 days so when i do i chk everthing
im today im focusing on a thourgh visuel inspection n tighten all and any loose bol fittin hoses btackets ect!@#$%^&*(
thank u all for the advise and any more i would appreciate
ThisIsNotaStep
2005 bx23 tlb
Nov 26, 2010
133
Ontario, Canada
I get the impression allot of folks only see the maintenance period as "every X hours" and miss the "or, every year" for allot of items on the Kubota maintainance charts ..
KUBOTA4900
Feb 3, 2013
65
i get the impression allot of folks only see the maintenance period as "every x hours" and miss the "or, every year" for allot of items on the kubota maintainance charts ..
i would have to agree with you as most of us know orange is not cheap
and any preventative maint will go a long way
even with all the records show after it got delivered i changed the oil n flushed the radiater
the 2 most inportant item to me
