B3200HSD Loader Arm (lever) Block and curl control ball link replacement.
jkahan
KX057-5, M5040, B3200HSD, RTV, ZD1211-60
Dec 26, 2013
27
9
vt
Big ask -- hoping someone can tell me how to actually replace a failed part. PIA in terms of space and acces. The ball link (part of loader arm assembly) that controls my loader curl failed. The screw that goes into the loader lever block sheared off; I've removed the block and have a new one on order (as well as a new ball link). Am thinking the only way to actually replace the ball link is to remove the metal bracket around the whole assembly. Any help would be greatly appreciated. thanks - josh b3200hsd loader lever interface-fotor-20240520165337.png
11,045
Remove the pin and pull straight up.
jkahan
Dec 26, 2013
27
9
vt
To beat a dead (but now fixed) horse... here is some more info on the Kubota B3200HSD Loader Lever Assembly - Other B models might be very similar.
Twice now, once four years ago, and again this week, the interface between the loader lever (operator control arm) and the hydraulic valve failed. Both times, bucket curl functionality was lost. The curl function is achieved by a bolt interface into a metal block beneath the loader operator control lever. This curl bolt /link is subject to stress (stripped bolt) over time.
Below is a photo of the lever assembly (fully assembled) and a markup of the same area. I've also included a snapshot of Kubota diagram F15200.
I usually use Kubota's Parts site (KubotaPad) and Messicks for diagram and parts help. I have had awesome results working with my local dealer, Messicks, and Coleman Equipment. Diagrams J28002 and J28400 are also useful; Part numbers are found on F15200 (but not shown in this post).
Repair Protocol for Lever Block and Curl link.
Obvious (easy) stuff - remove seat, tool box, plastic shield, right side metal shield, metal support beam, and of course, the loader (operator control) lever. This will allow one to remove the metal block (010 in the diagram below) that the loader lever is attached to. The horizontal metal support beam has to be removed to gain access to the bolt (060) that attaches the lever block into the metal bracket. There is also a collar (050) in the block that this bolt slides thru. Despite what I have read, it is IMPOSSIBLE (at least on the B3200HSD) to replace the curl interface (part 030 and stuff below it if necessary) without removing this metal bracket - not hard to do - just 4 easily accessible bolts and a spring (part #130); Diagram J28002 shows how this bracket attached to a bracket on top of the hydraulic valve.
Anycase - maybe this is obvious to some but its a once in a blue moon problem (or at least once every 4 years) for me. While I am grateful for the comments and help that I received, here and elsewhere, I did want to point out that on the B3200HSD it is IMPOSSIBLE to do this repair without removing the stuff noted above.
thanks for listening:)
-josh
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
197
271
Hardy, VA
Found this writeup as I had the same failure on my B2620 on Saturday. I got it all disassembled and ordered the new rod end.
Hope to put it all back together this coming weekend and be back working. Will follow up with how it all went to add to the collective knowledge for others who find this thread.
I found this youtube video that I post for posterity despite the fact that he does not film any of the interesting parts.
trikepilot
Jul 18, 2020
197
271
Hardy, VA
Further update for those that follow me down the rabbit hole on this issue loader curl issue.
The part # required is:
#45404-95770 END, ROD (CREEP)
I linked the part at Messicks above but it is more expensive, has shipping costs, and takes longer to get to you. For cheaper and faster part use this:
I ordered Sunday night and it arrived Tuesday. I came out to the farm after work on weds and had it all reassembled and working perfectly in 30 mins.
This is not a hard DIY repair. It is a bit finicky to get access in there and some long skinny hemostats really made it pretty painless.
MattB3200
2010 B3200 with LA504 loader
Dec 1, 2025
Otter Tail County MN
Hello to All! New to this forum and having the issue described here, with the exception that I can't find anything broken. The great info here is what sparked me to do this myself. When the loader lever is moved a few times the ring on the end of the detent valve rod ("B" in the above referenced diagrams that has part #030 et al connected to it) keeps slipping off the pin causing the Loader lever to wobble around and not work right. It's not hard to slip the ring back on the pin but 2 minutes later is slips off again. I removed the rod and it appears that the rod (030)is adjustable. I think I have it as short as it goes right now. Does that rod have to be adjusted to a specific length? The pictures show the ring all the way off the pin and part way off. I'm planning to remove that rod again and adjust the length but it would be nice to know whether I'm barking up the wrong tree or not.
