L3130 Losing power going up hills after Fuel Filter Change
May 6, 2017
tulatin
Hi,
The tractor was running great until I changed the fuel filter. After changing the fuel filter, the tractor loses power going up grades, which wasn't an issue before. The tractor's RPM seems to cut out. When I let off the pedal, the RPM jumps back up. I'm guessing it's an issue with bleeding the fuel lines. Looking for suggestions?
Thanks
Chris
Tractor L3130
Hours 790
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
642
255
Herald Calif.
Did the small bleeder valve by the injection pump get left open? Tractor will run fine until it needs more fuel.
airbiscuit
Mar 18, 2021
214
150
NW WI
Bleed the system. See if that helps.
Start at 1:55
