Things you'd never seen
WFM
L3800
Apr 5, 2013
1,527
977
Porter Maine
I gave a buddy a ride to drop off his diesel pickup to be serviced before he heads to Alaska.
The turbo diesel folks are having a new shop built. As I waited for my buddy.
The carpenters and a kubota skid steer were setting truses with a retractable pole on the front of the skidsteer. I watched them do two in no time. What a cool tool for contractors.
7,083
Yeah, there's been a few folks showing how they set trusses with their tractors, SSL, etc.
Had some pretty ingenious booms set up for the task.
Pretty neat.
7,080
The topic is: Things you'd never seen. How about the counter weight? Ever seen one like that?
BAP
Dec 31, 2012
3,048
1,165
My father and his 2 brothers built a 75’ x 200’ freestall barn in 1962. The main trusses were 60’ wide. They set them with a IH 350 tractor with loader and homemade boom. We built several barns after that using a boom in a payloader.
9,805
I bought a boom pole from CAL (CAI) a few years ago to put up steel trusses. I've designed the trusses and will be welding them together this spring/summer. The boom is rated for 1,800lb at the end.
Here's the boom pole on the MX, but I'll be using it on the M6060 given the increased elevation and lifting capacity.
3,682
How ‘bout THIS?
5,183
Those are the economy trusses.
In a North Idaho snow load environment, those "trusses" are a very bad idea!
Design may(?) be OK, but connectors are UNSAFE!
Perhaps..... OK in Tucson?
9,533
Tractor boom is a practical/good idea!
Homemade trusses!
Terrible idea..... using SMALL squares of chip board as truss plates!
Likely would NOT meet code anywhere!
My house has been picked over by many a person, most just do it in person and not from 3000 miles away.
Well smarty pants, you don't know as much as you think you know.
My house is 100% custom built to be super efficient, super strong, and super high tech.
If i told you what it cost me to build and what the house appraised out at, and what it would sell for, it would give you a heart attack!
Yes the trusses are hand made, as is the rest of my house, but they are 120 PSI 2x6 top and bottom cord engineered trusses.
I have the stamped engineered blueprints.
Laser measured deflection was less than 1/4" across 40 feet clear span with 6 feet of wet snow on them.
120 psi is twice what is required for our heavy snow load.
Oh and FYI, I also build and remodeled quite a few homes in Phoenix, Scotsdale, Carefree, Cave Creek, and Paradise Valley, AZ and their trusses can have more load than snow load specs, because of heavy roofing coverings like stone, tile and slate.
They are also built with better lumber than what a truss manufacturer would use.
All tamarack / larch that is grade stamped Select GOLD or also know as Select structural (best of the best) .
And yes the tie plates are OSB, that are construction adhesive, 2 1/2" stainless stapled, and ring shank nailed.
There are a ton of articles and engineering studies done on this type of truss manufacturing
They do not fail over time, or under extreme weight shifts.
They also do not fail over time like small stamped metal plates.
5,183
Hummm.......
"smarty pants"?????
Insult intended !!
I thought that sorta stuff was not acceptable here.
Silly me..... .
The plans may be great!
The lumber, may be fantastic!
Perhaps you have previously built a ladder to the moon.
Stamped/approved truss plates meet nationwide codes.
Is the code so different in North Idaho, as to allow undersized homemade chipboard connectors..... that place where tar paper is king?
WFM
L3800
Apr 5, 2013
1,527
977
Porter Maine
Lol...your to old win a pissing contest Fried.
I have several collar ties in my cathedral ceiling but I made them out of 3/16" stainless plate. No rusting.
5,858
the building I used to own was 40' wide, 72 ' long. Trusses clear spanned the 40' and were/are 12' on center. Built back in 1963/4. Building is still square and true. Designing trusses on 2' centers has to be 'child's play', though maybe good wood doesn't grow on tress anymore ?
the new house up the road is single floor yet the roof is 2 stories tall !! I counted 9 or 10 '4by8s' . Have no idea why the owner didn't use 'floor and roof' type trusses. at least HAVE the potential to ADD a second floor up there.....
5,183
Most/many DIY building projects are not to code.
Electrical is even worse!
5,858
'code'... yeah, there's a joke.....
The city I'm in , demanded the timber framer bore a hole down the length(12-16') of every member of every bent in a timber framed structure and BOLT them together......
I'd love to know how 'they' would bore a hole down the center in a 16' long , 12by12 of pine !!!!
heck, I'd pay real money to see them do it, even just ONCE !
Reminds me of the recent show about how ancient Chinese pagodas have withstood the test of time, 100s of years yet newer buildings, 'made to code' , fall down and go boom when Mother Nature shakes the Earth.
Electrical 'code' is weird. Look up the specs for the new 'arc fault' breakers that must be used in Ontario,well except for 'critical' circuits.....
5,183
I know from personal experience, that in 2006, Nova Scotia did require "arc fault" breakers in all sleeping spaces.
Apparently the USA now requires them in other areas as well, for new construction.
5,157
The "arc fault" breakers are great until you want to use an appliance, such as a hair dryer.
