PTO Driven Water Pump
Titan Missile
BX1880
May 10, 2024
Upstate NY
Hi all, was looking to see if anyone had a recommendation for a roller/ washdown pump for a BX series. Basically what I am trying to do is use the tractor to move water around the property. We have a couple of ponds and garden beds scattered about and it would be ideal to take from the pond rather than the municipal tap which is chlorinated and costs money. I also have a stormwater pond that needs to get drained down.
I've seen large water pumps mounted to heavier equipment that can move crazy amounts of water. Really just looking for something that would substitute the garden hose.
Any input is much appropriated.
2,551
Curious - would a stand alone be cheaper than a PTO driven one?
And would you want your tractor tied up for the duration of pumping?
5,066
I too would recommend a stand alone gas powered pump!
Much more versitile, and can be easily sold if/when no longer needed.
Probably cheap at HF.... but, buy their 2 yr warranty!
Vlach7
L47 305DT JD500C
Dec 16, 2021
346
252
Frazier Park Ca
HF has them for cheap, but between the hard suction and how far the discharge hose is going will be the additional cost. Had my 2" for 15 years and it still works great, 100gpm.
6,378
The normal roller pump that are PTO driven, would be a VERY poor choice for moving dirty water, they will wear out in short order.
You're much better off with a sump pump or a trash pump to do the job.
Titan Missile
BX1880
May 10, 2024
Upstate NY
Thanks for the feedback. I think a stand alone trash pump has been added to the ongoing term list of wants. It seems to be better suited for moving large amounts of water. Was curious if something like bilge pump could be used to fill smaller totes and move the totes around with the tractor. Even the manual bilge pumps could work, I don't mind putting in some effort.
