Using glow plugs or not using
lmichael
Kubota G2160
Apr 23, 2021
605
254
Rockford IL area
So, I'm just wondering. I know the glow plugs are there to help "light off" the diesel sooner and start the engine easier. But, if it's warm outside and you simply crank the engine a few seconds longer is there any harm to the engine by not using them? (other than running the starter a few seconds longer).
Fordtech86
L3200
Aug 7, 2018
4,976
5,917
Pineville,LA
I rarely use them (although I believe some models will still activate when cranking). I usually don’t use my tractor if it’s under 40 degrees or so though 🤣
2,551
Really depends on the model and age of the tractor.
I have 4 kubotas - I glow them ALWAYS and some times longer than I may need too - overglowing does not hurt a thing, UNDERglowing will get you a lot of smoke and sometimes a hard start.
If glowing gets a quicker start - that little bit of heat helps the starter not spin as often too.
I even glow after an hour of sitting ......... on a warm DAY - no, the glow aint real long!;)
jaxs
B1750HST
Jun 22, 2023
735
522
Glow plugs save battery and starter. Hot plugs ignite fuel on every revolution which HELPS starter turn engine. I use them every time regardless of weather. A "well desighened" system turns light off sooner when engine and/or weather is warm. Those that own Duramax,Cat,Cummins,PowerStroke and such will notice this,engines from the land of just barely good enough not so much so.
4,816
My Lister Petter engine has glow plugs and a heater inside of the intake chamber. It starts very quickly no matter how cold the engine block is. It also has a block heater, but it is rarely ever used.
David Page
Jun 25, 2013
384
68
Dexter, ME
I use mine most of the time unless its been running recently. The old 2 cylinders start hard.
6,381
The glow plugs on a Kubota heat on crank regardless of a pre heat.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,117
1,234
Near Lancaster, PA, USA
On the Kubota I twist the key enough to get the GP indicator on and wait till it goes out to crank for the initial start of the day. Normally the tractor isn't shut down long enough to cool to the point of using the GP's a second time.
Ford (Shibaura) has a heated wire indicator rather than a light and doesn't go out automatically. It really doesn't like to start without getting the indicator glowing pretty brightly - especially in cold weather. But again, if it's not shut down long enough to completely cool it starts fine without the GP's.
2,816
they heat the air in the cylinder, they don’t ignite fuel…some diesels use a grid heater in the intake to heat the incoming air (Cummins? 🤔)
Yes sir. (y)
I do not actively use the GP on the General Lee when its warm'ish out. (above 65'ish?)
My Cummins does not even have the option to use it when it's warm out.
I have to turn the key to the "on" position and look at the dash, then computer auto-magically senses the temp and either lights up the "heater on" signal (a small curly looking sign) or not.
If it lights up, you wait until the "heater light" goes out while it heats up, then crank the engine.
If it does not "light up", you can just crank it.
4,908
I preheat for 5 on-offs of the 4 ways on my BX23S. For 6 years, 1200+ hrs I've done this unless the engine is still warm. It has always started easily, Winter,Spring, Summer,or Fall. Probably not 'necessary' but 'if it ain't broke not need to fix it' !
5,066
I never use glow plug heating on my little 32HP 4 cyl. Shibaura, and it starts just fine.
Of course, I never use the little Ford in Winter either.
She, is my baby!
lmichael
Kubota G2160
Apr 23, 2021
605
254
Rockford IL area
So, no "harm" to engine itself? Maybe a little extra wear on starter? And a little extra smoke. The garage was about 75 deg. And, I simply cranked (mostly because I forgot). Seems if I am at somewhat warm ambient temps like yesterday and I don't use the plugs, the engine will crank about 5 or 6 seconds. If I use the plugs in same conditions, I don't think it takes 2 seconds to fire. Almost feels like it barely makes a full revolution and it's "lit". Unless it's cold. Say mid 30s up to about 45 or so. Then even using plugs it will spin a bit before it lights off.
But really my question is related not so much to how easily it starts using/not using but whether there is any "harm" to the engine itself
4,908
'harm' by not using the glowplugs...
possible include..
1) extra wear and tear on battery. assuming starter needs more amps than glowplugs
2) extra wear and tear on starter.more use = more wear...
3) 'fouling' of head,piston.raw fuel in cylinders(black smoke)
I think glowplugs draw about 10 amps each, so 30 total. HAS to be less than starter amps ?
imnukensc
BX2380
Sep 10, 2015
688
591
Midlands of SC
I have no clue what this means.
I always use the glow plugs for the first start of the day no matter what the outside temperature is. As others have said, if the tractor is still warm after a shut down and I need to restart, I don't use them. If it's completely cooled down and I need to restart, I'll use them again no matter what the outside temp is.
3,316
The only “harm” I can think of is the few extra revolutions which may occur in which oil pressure is not-yet up to standard.…but that concern borders on negligible.
As Wolfman says… the glow plugs energize when the key is turned to “start” …regardless…. so glow-plug activation occurs at every start.… There’s just no “pre-heat” so an extra few revolutions might occur in very cold weather.
I use preheat whenever it’s cold-enough that I’m wearing a coat. Otherwise…. no.
2,965
GVJay said: "I preheat for 5 on-offs of the 4 ways on my BX23S."
I think it means he turns on the flashers before he turns the key to the glow-plug-on position… he then starts counting when the glow-plug light comes on. I’d probably just do 1001, 1002….
chim
Jan 19, 2013
2,117
1,234
She, is my baby!
My little (half the HP as yours) Ford 1210 doesn't like to do that initial start without GP's even on warm days. She'll start in any temperature with them though. It is good mechanically, and could use some paint. Scrappy little thing that acts more like a tractor twice its size. Original plan was to sell it when we got our first Kubota in 2002. Can't seem to part with it:)
Flintknapper
L2350DT
May 3, 2022
1,767
2,226
Deep East Texas
My technique as well.
5,066
Same here!
I bought my 1989 Shibaura FEL with 1,000 hours, 8 years ago.
Bought my 2006 L48 TLB 3 years later.
I have completely refurbished the Shibaura, including paint and tires.
It ain't goin nowhere!
It will go with me to the grave!
