Stand or Storage Options
RobAndress
BX2370
Apr 21, 2024
Cornwall Canada
I'm wondering if anyone has a stand for their pine rake or land rake? Something you store it on that allows you to hook to a 3 point hitch without getting a hernia?
Let me know what you got..
johnjk
Apr 13, 2017
1,816
2,236
West Mansfield, OH
No rake but the rear blades are a similar design and concern. They either want to roll on their back or tilt forward with the top in to the ground. I use a couple of dolly’s from Harbor Freight and rest the blade on the back. It allows me to easily position the attachment and get the lower arms attached. Once this is done I can lift it off the dolly’s, lower it down and position the blade so the attachment is in its upright position and attach the top link. If no concrete for dolly’s then you could build a small support out of steel or wood that will keep the 3 pt attachment elevated so it is easier to attach/remove.
Fordtech86
L3200
Aug 7, 2018
4,966
5,919
Pineville,LA
I’ve got an old trailer jack ive been meaning to put on mine, just haven’t gotten to it. Think @RCW came up with something on his (it might have been on a blade though)
bird dogger
Feb 24, 2019
1,810
1,784
North Dakota
Hey Rob,
Here is my stand setup for my landscape rake. See post #16 and later for the pics and hitch mods. the stand brackets were made from some scraps on hand. They're not quite as handy as I had hoped....but they work.
If I was to do it all over again: I'd make a single "drop down" stand that could just be pinned in either the up position or the down position.
Without the added "ears" for narrowing the hookup, it was a pain to hook up to my B2650. I don't use a quick hitch. Having a narrower spread for the pins made hookup much easier.
GrizBota
Apr 26, 2023
1,147
733
Oregon
Not to take away from some other neat ideas for stands, but if we’re taking about the landscape rake like @bird dogger has in the link above, with wire tines, could an upended 5 gallon pail work? The load would be maybe 20-30 lbs.
6,871
I put mine together on the 3 point and when it was all together wanted to take it off but didn’t have time to make a proper stand so I used a square U-bolt and a scrap piece of 2x4 to make a leg to hold up the front of it. Took almost 5 minutes to make. Originally intended to make a better stand later. I only use it a couple times a year and the 2x4 works so I’ve never “gotten around” to making a better stand.
For mine, it’s not very heavy at all so it doesn’t take much to hold it.
