MX5400 wheel weights
Ajmtman
Kubota MX5400
Mar 26, 2024
Minnesota
I am looking for some used wheel weights for a ‘22 Mx5400. It has 24” rims in the rear. I found some F and N weights with “W161” and “W162” on them. They are “universal “ weights. I read that the 161 goes inside of the 162. Wondering if these would fit my rims. The bolt pattern on an MX is 4 bolts, approximately 12 3/4” diameter. Has anyone tried these or know of another weight that will fit?
mcmxi
6,336
NW Montana
I have no idea if those weights would work for your MX5400. I have the factory weights on my MX so that's an option for you.
Ajmtman
Kubota MX5400
Mar 26, 2024
Minnesota
G.rid
L48 tlb, ssqa forks, manual thumb for hoe
Aug 19, 2016
207
17
Oxford, NS, Canada
Thanks for the pics. I’m just trying to avoid giving the dealer $1700 for 3 sets of weights and a bolt kit. Thinking about beet juice in the tires. I don’t like how far ballast boxes stick out the back. Don’t know which way to go.
If that ad is still up, it's only $40 bucks. As long as the diameter is small enough to fit inside the rim, you could drill new holes to match your pattern.
The cheapest I've seen them around here is $250.
mcmxi
6,336
NW Montana
Got it done. Weight box weights 600 lbs. empty. Old JD wheel weights slightly modified, 150 lbs each. Total cost $180.
Can't beat the price! Looking at my MX spreadsheet and bill of sale, I paid $1,305 for three sets of wheel weights, hardware and installation.
For the MX the factory weights are 100lb each which adds up to 600lb of total weight. The M has 990lb of wheel weights.
hedgerow
277
246
Malcolm NE
Those like to be for the old A-B-G John Deere tractors. Have some of them that have been on a JD A tractor since my FIL bought it new in 1950. You have your self a cheap weight set up.
FTG-05
Jul 21, 2013
282
115
TN
Make your own out of lead, steel and concrete:
240 and 260 lbs each (difference is amount of lead) for a total of 500 lbs. Pretty much just for the cost of the concrete mix and 12 8" Gr8 bolts and nuts.
