Recommend wheel spacer brand
Tonka
71
50
usa
Looking at putting 2" rear spacers on my LX2610.
Stahl/Steel or Bora or Bro-Tek ?
OntheRidge
Nov 1, 2020
500
589
On my 2nd set of Bora's (2 different tractors), beautiful product, easy install, and above all, great customer service! And, made in USA. Good Luck!
Garvini
Kubota b26 hydraulic thumb pallet forks
Apr 4, 2022
32
19
Hingham, Massachusetts
I went with steel from Messicks…kind of expensive… 1.5 inches just in case I want to put on tire chains
RMS
Sep 26, 2021
315
685
Buckfield Maine
I went with 2.5" bora spacers on my lx2610. Rear tires stayed just within the width of the bucket.
5,164
Today I picked up a used pair of 2" spacers for $40 locally. The seller didn't remember where he bought them but there was a number on the spacer. Using that number I found that they were sold by Walmart (presently out of stock) and they fit Fords and Lincolns. Took that description and put it into Amazon and found them for $59 new and $48 used but look like new. This is how Amazon sells items the packaging is torn and the product returned. Saved $8 plus the sales tax and would have had to wait a few days to get them. These are used and look like new except for the dust from his barn.
acruxksa
LX2610, lx2963, bb2572
Jan 15, 2024
46
114
Anchorage, Alaska
Just get the ones that meet your price and delivery expectations. Plenty of other things in life to actually worry about besides wheel spacers.
That being said, no doubt somebody on here lost everything including their dog because they didn't buy one specific type of spacer.
Earl II
2021 LX2610
Jan 1, 2022
11
9
Idaho
Went with 3" Bro-Tek for our LX2610. It already had kubota dealer installed 1 1/2" spacers but I picked up some gargantuan Trygg ladder style snow chains. The inside shackles came too close to the hydraulic lines on the outside of the right frame area. I will let you all know how it turns out when I get them installed. Bro-Tek assumes that you don't have spacers already so their instructions are close but don't work because you are short four of the tapered head stud bolts. Looking forward to getting it done.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,541
central ct
I went with the Bro-Tek 3". Its been 4 years so far on the L3800.
Earl II
2021 LX2610
Jan 1, 2022
11
9
Idaho
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,336
859
under a rock
I installed these over 5 years ago.
No problems.... bolted right up.
At the time they were $33.00 they are now $52.00
Billet alum. 6061? not sure....
But I would bet a dime to a dozen donuts that they are the same as the high dollar units.
All I know is it sure beats paying $250.00 or more for the name Brotek
My $0.02
3,399
My $0.02
Easy to find those for the BX. I have similar on my BX 2200.
More difficult to find something like that which will work for a larger tractor. I ended up going with 4 inch BroTech on my B2910.
John T
May 5, 2017
1,336
859
under a rock
True.
OP has a LX2610 "I think" those are 6 x 150mm you can prob find a set if you dig deep enough into the dark web...
B2910 .. I have no idea.
Dusty71
LX3520, SCAG Tiger Cat 2
Apr 7, 2023
52
31
Warrenton, VA
Tonka, I’ve got 4 inch spacers from Bro-Tek. Absolute game changer on hilly land.
Richard from Bro-Tek is dynamite. Prompt follow up, he has many spacers in stock & is easy to deal with. Shipping out of Canada … so keep that in mind.
Please keep us posted as to which direction you go.
Shawn T. W
Dec 9, 2024
815
1,485
SW Missouri Ozarks
While an old thread ... OP hasn't responded yet on what they did, or didn't do yet ... ?
I'm very happy with my BRO-TEK's, I went 3" on the rear, and 1.4" on the front of my SCUT ... Almost three years ...
Earl II
2021 LX2610
Jan 1, 2022
11
9
Idaho
So BroTek 3" spacers installed on the rear. My Trygg modified snow chains on the rear have now plenty of room to do their job without the possibility of any damage to the frame and cab area underneath. Glad I did the research and got this done. Used the box snow pusher yesterday and all is good.
11,155
You've been handing out info on putting spacers on the front.
That's 100% bad info on a kubota, You do not reverse rims or put spacers on the front axle of a 4wd kubota.
Then I looked at all your posts, you haven't once said what Kubota you have? :unsure:
I'm suspecting you don't have a kubota, as you only refer to your MF and JD but not a Kubota.
Shawn T. W
Dec 9, 2024
815
1,485
SW Missouri Ozarks
Your correct I do not currently own a Kubota ... I clearly listed what I own, and read that I don't need to own a orange tractor to join or post, is that not correct?
But how is one MFWD tractor with a pivoting front axle so different from another?
Please explain WHY Kubota's can't have a wheel spacer on the front axle?
In my experience and testing a wider stance does add stability on the front once it hits the axle frame point, which on my tractor is about a 4" bump or dip.
  • Dislike
