Sorry - got the numbers confused so you are actually quite a bit low. I would still attempt adding some shims to see if it bumps the pressure up.Ok, shouldn’t it be 2633 at idle? Kubota gave me this.
At this point there are two variables in the circuit - the relief valve and the pump. You said you put in a new pump so it should be capable of way more rhan 2600 PSI. That suggests the problem is in the relief valve.
Testing the pump without the relief valve in the circuit is a bit involved. Boosting the relief to see if the nymbers change is a lot simpler.
