ayak
L3301 HST
Feb 16, 2018
776
1,270
WV
Finally got that gate up, so Evil Twin can’t bring his Box Blade back 🤣
Reactions: 7 users
ayak
L3301 HST
Feb 16, 2018
776
1,270
WV
By the looks of it he could just drive around!
I was thinking he might just go all full-out Knievel and get it done that way.
5,163
I greased the loader today but had to take the loader off to get some of the pins to take grease. Some grease nipples still had orange paint on them, but they did take grease. Also, found that my Lock and Lube grease gun tip has a manufacturing defect. I will be calling them in the morning to see what they advise. I did find one grease nipple that was broken off and none from my assortment didn't want to screw into the hole after I removed the broken piece. It must be a Metric thread.
5,187
"Metric thread" ???
Only fits your metric grease gun ? ;)
6,969
part DUX...
thought it would be just a few hors...nope...all day event. U-27 did a great job for me again. We already got another google 5-star review. We like those.
dig
pipe
time for backfill
that's a wrap.
tomorrow will be a powrmole job with the tractor/backhoe.
Reactions: 11 users
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
461
534
NE Ohio
Usually 8mm.
5,163
It the head on a Metric grease fitting the same as a standard US grease fitting that was produced in the US 50+ years ago? When I compared the head where the grease gun grabs the nipple, it looked a lot different than what is in my 50+-year-old grease fitting assortment or is it just the manufacture of that particular Metric grease fitting?
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
355
235
Eastern PA, USA
Spent a couple hours clearing dirt. Had to remove a foot of earth due to a hydraulic leak then move more dirt in the backhoe. Then leveled the ground more.
Reactions: 9 users
JimDeL
Aug 31, 2022
461
534
NE Ohio
The ones I have look the same, and my Lock & Lube fits them. The 'neck' might be a bit longer on some, but the 'knob' is the same.
6,969
PowRmole job with the tractor today. All went fine. not many interesting pics...
Ready
broken fitting
30' of new pipe pulled with the powrmole. It pulled hard against the trench wall. I think it was trying to get thru the foundation wall of the house addition. The thing is with this system, once you start pulling, you just have to keep going until it either completes the job or separates that cable.
Backfill
done
Reactions: 6 users
Old_Paint
Dec 5, 2020
2,035
2,299
AL
Ready
broken fitting
Backfill
done
Man that was some happy grass before you fixed the poopy pipe.
mdhughes
L3901DT
Dec 10, 2014
1,451
1,492
Ste Geneveive county, MO
This is one of best pictures I have seen on the forum that doesn't have anything to do with tractors :giggle:
Old_Paint
Dec 5, 2020
2,035
2,299
AL
Well, I'm going out on a limb here, and gonna say that if I post one of my home brew setup, it's gonna be because I had to move the tractor outta the way to set it up. I brew in the tractor shed and tractor in the brew shed. Ergo, beer does have a connection to tractors.
Any other kinda beer, I might have just agreed with you about it being the best photo, though. I've been to the Guiness brewery in Dublin, and that stuff didn't taste any better within 100 feet of where it was being made than it does after a trip across the Big Pond. I tried, REAL HARD, to finish a pint in the upstairs pub at the brewery, but just couldn't do it. Much too bitter for my tastes.
Hang on a minute, I just saw the heat lamp and some chicks in the background. Maybe he's feeding the chickens with Guiness.
11,758
I spent about 30 minutes around midday yesterday filling in and grading the mess at the bottom of the driveway. I had the M6060 bucket on the MX which has a smooth bolt on cutting edge that works well for back dragging and such. As luck would have it (or not), a county grader drove past on the opposite side of the road as I was working, and then came back along my side when I was done. I had no idea that grading was on the schedule and I'm still not sure if my efforts were for naught.
When I got back to the house I discovered that the power was out due to a big fire at a motel about 5 miles away. It took close to 6 hours before power was restored.
Reactions: 7 users
5,187
Yup......it tastes like what I imagine a mixture of linseed oil, and cesspool water might be.
g_man
Feb 3, 2023
380
1,775
NE Vermont
You could use the as a stone boat - :)
TwitchyMcJoe
1980 L185DT
Yesterday, but: I jacked up my L185DT and finally removed the FWD portion of my 4WD to repair it. To my horror, I saw that the bevel gears were eaten up, there was a hole in the casing where part of the bearing shot out like a bullet, fragments of bearing and oil seal were everywhere.
But, at least I can get parts.
Bearing... what bearing?
20240410_192357.jpg The "Bullet Hole"
And lastly:
You can see where the balls from one of the failed bearings fell between the gears.... and somehow this thing functioned well enough that I bushhogged a three acre field without noticing.
