B1630 FEL in need of tilt rams
Garrettl1515
B1750 B2150 L3350DT L345DT B7100HST B7100 L2201 B6200
Feb 19, 2024
46
21
Bakersfield CA
Hi guys I bought a b7100 and they made some Frankenstein modifications to the b1630 loader. I’d like to return it to original. I’m missing the front tilt rams, anyone know the size or where to get them?
7,240
If you give me the pin size and short length and long length IO can point you to them.
to figure out short length, roll the bucket all the way back and measure pin to pin.
To figure out long length, roll the bucket all the way over and measure length.
Garrettl1515
Feb 19, 2024
46
21
Bakersfield CA
The rams are missing I’m unable to get that:(
2,717
I think NIW means to manually move the bucket & measure the pin hole to pin hole dimensions in both positions, fully rolled in each direction.
7,240
All of those measurements are based on what you have in front of you.
EDIT: Lil Foot said it better than I did.
But looking at your pictures what's in front of you in not what you need.
You're going to need to get a stock bucket to get the measurements as it doesn't look like you could put the needed mounting points on that bucket.
4,711
Here you go - new aftermarket cylinders on my B1630.
Bucket cylinders:
Garrettl1515
Feb 19, 2024
46
21
Bakersfield CA
Bucket cylinders:
Going to order them now thanks Dan
