L3302 Seat Switch fix help
Impala
L3302 prior B2601, prior BX2230
Jan 16, 2021
104
73
WI
I have had an L3302 since they first came out. Love the tractor except for the seat switch. A few people have asked about it but there has not been an answer. The 3302 has the switch in the seat so it is different than the older ones. I don't want to bypass it completely or put a toggle in. I simply want it to be less sensitive and work as designed. When I am plowing or cutting if you try and look over the tractor it shuts off.
Thanks!
loggin
MX4700
Sep 4, 2021
111
39
canada
Thanks!
Is the switch built into the seat or is it separate? Perhaps you can take a picture of it and post.
Maybe there is a way to make a spacer so it doesn't trip as easily?
jaxs
B1750HST
Jun 22, 2023
1,008
779
Simplest solution I can see is a momentary switch button to push while standing (raising up from seat).
9,912
Thanks!
This is an issue normally with lighter people.
Adding a piece of foam or a plate of some kind will help with reducing sensitivity.
If it's still under warranty address this with the dealer and they may just opt to get you another seat.
