I'm getting ready to make a home made (concrete) ballast weight for my BX2380 sub compact. I got in a situation with the FEL and the tractor felt super duper unstable. I want to balance the weight out with a rear ballast from the quick hitch when I use the FEL.
Question is: My calculations show I'll be adding right at 340-350 Lbs to the at the quick hitch. Will this be enough? How much weight are you putting on your quick hitch/3 point for use as ballast weight?
