BonnySlope
BX2380 FEL Add-A-Grapple, Titan 48" Box scraper, 60" Rake, 72" Rear Blade, Flail
Hi, started a new post on my Howard HR10, got a good deal and I'm still having fun. As you can see chain has a little slack in it and out of adjustment bolt length with jam nut. I was thinking, could that be the sprockets getting worn! If I length the adjustment bolt (.50 jam nut thickness), would that be enough for limited use. As you see the chain doesn't touch when tensioner slid over. If I was to put new sprockets on, I would measure length of chain (20B-1) and if needed replace also.
Sorry, main question is I have Howards part number 647821 (Z=16) tiller lower sprocket and 647822 (Z=11) upper drive sprocket. spanner nut size for Z16 is M40 for M35 for the Z=11. Would on call Ag parts house found on Net. My search comes up with racing sprockets and others that look completely different. Any thoughts,
