wet brake replacements
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
681
155
Rising Sun, MD
Guys (and gals) I have owned my B2410 since new 24 years ago. My brakes have never been adjusted. Like the army of Kubota owners that have come before me.... they have operated the tractor with the break pedal locked down. Aside from killing the hydraulic oil we have prematurely wore the breaks down.
I change my hydraulic oil annually {major over kill).... but now they really need adjusted at minimum.... maybe even the brake packs replaced.
Tell me what you think. Especially interested in what it takes to replace the brake packs. Butch
3,502
Travelling at moderate speed…stomping on the brakes….DO they STOP you within a few yards with no loud grinding/squealing…?
You don’t need to do anything but adjust the mechanism for wear.
Do they NOT stop evenly and pull to one side or the other and grab/jerk/release/repeat…?
Time to replace the brakes.
8,807
Try adjusting them first!
Wet brakes are very, very tolerant to being left on and to being used a lot.
I honestly can't even remember the last time I had to replace a set because of wear.
NorthwoodsLife
Oct 15, 2021
1,286
1,281
Wisconsin
Spot on. As usual with Wolfy. (Pardon the terminology. Sorry, Sir).
Tractor brakes should last 50 years. Unless you ride the brakes, or they rust the backing out.
Think about it. The machine travels at less than 5 mph almost all the time. And the brake construction of the pads is nearly the same as street vehicles.
Nicksacco
Sep 15, 2021
713
423
Bahama, NC
Like my L35, yours seems fairly straight forward on the adjustments, like part 030. Have you a WSM that gives the specified amount of free play?
My linkages were so badly rusted, the hinge points were very stiff and it appeared that the brakes didn't work.
Butch
Sep 10, 2009
681
155
Rising Sun, MD
Thanks everyone!
I adjusted the brakes and they are as good as new!
kcs
Kubota B2650
Jan 9, 2021
148
I did the same thing yesterday. Cut about 3 acres with my B 2650 and was wondering why the cruise control wouldn’t work. When I went to put it back on the trailer and set the parking brake I knew why. Hopefully i didn’t mess anything up.
3,194
1,620
The only ones I have replaced in the last 20 years were from someone telling the head of maintenance at a local city motor pool that you can use ISO46 instead of SUDT in their M series tractor. He was surprised that 60 hours later it only cost about $9000.00 to repair the carnage.
