fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
355
235
Eastern PA, USA
Nice day out. Moved about 30 yards of dirt to unburry a tractor. Graded the area real good, will be putting garden there. B8200 did the grading, b7200 did the dirt moving and rescue my old new holland and took it to the shop. Just turned dusk so timing was perfect, set up in the shop and started to tear down the new holland.
5,164
Finished assembling the Land Pride land plane, and then mounted it to the tractor. Works well, but when the tractor went into a few depressions, I got butterflies in my stomach and decided that I had to get the front weight box onto the tractor before I go any further. I also learned that none of the 3 York rakes I have will fit on the quick connect on the 3-point hitch without many modifications. Have to sleep on it, sell them all, and just buy a new one, or spend a lot of time making modifications. I have been sick for the last 2 weeks, and am just starting to get outside again.
Toyman
B7100HST, 1630, 4' Tiller, 4' Brush Hog; Mahindra 5005/Loader, Woods Cadet 84,
Apr 15, 2019
120
104
Pittsburgh
Not all in one day, but I traded my 3,500+ hour M4050 (sad to see the M go) on a 500 hour Mahindra 5005 with FL in excellent condition. Changed the oil in the B7100. Hooked up the 4' rotary cutter and hauled both to the farm. Dug out a few buckets of rocks to fill a sink hole, cut some stray trees/saplings and hauled away, and finally cut last years pumpkin and sunflower fields to get ready for this years plantings. Spring seems to be here and lots to prep work to be done.
11,757
No work with the tractor, just pure pleasure unloading around 700lb worth of Yamaha goodness. It's always a good day when the delivery company shows up and there's no damage to the crate or the contents. NPT has been good to me over the years.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Is it a jet ski? I bet it’s a jet ski.
11,757
Ha! Ha! No ... it's not a jet ski. It's a 200hp 4.2L V6 outboard. :ROFLMAO: I'll be selling the 150hp 2.7L I4 outboard once I've completed the swap. That motor only has 265 hours on it so it should sell fairly easily.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,540
central ct
During our recent stay in Florida we went to a resturant on the water. My friend and I walked around the docks looking at the boats - mostly outboards and Yamaha seemed to the motor of choice.
I believe this is 4 400hp and 1 300hp example - wouldn't want to pay for a day's gas!
Old_Paint
Dec 5, 2020
2,038
2,307
AL
You know what BOAT means, right? Break Out Another Thousand.
11,757
That's over $100K of engines out back and probably 2,500lb of weight. I wouldn't mind having two engines hanging off the transom, but I don't get the tri, quad and pent set ups. Just seems like a lot of money, a lot of fuel and marginal gains.
The other weird thing with odd numbers of engines is the prop rotation. You would normally have even numbers of left and right rotating outboards to balance thrust. With odd numbers greater than one, is the middle engine the "spare tire"?
GrumpyFarmer
5,200
Maybe it’s the trolling motor 😆…for the smaller bodies of water! (I assume Ohio is not only state with the HP rule for smaller lakes?…anyway it was a joke)
I did see Honda now has V8 (350hp) outboards…a pair of those would be a good start.
OntheRidge
Nov 1, 2020
495
588
And then there is these guys!!
ajschnitzelbank
Aug 24, 2021
271
700
Rensselaer County NY
My starter went the other day. There was a nice cold puddle where I needed to lie ok my back to replace it. So I moved it with the tractor!
Reactions: 7 users
SAR Tracker
Nov 17, 2020
256
390
Central Oregon
Ordered a BXpanded Talon Ripper tooth for my BH77 today (3/12). 5-7 days lead time - we'll see how long it takes to get here (TN to OR)
Incredible! 7 calendar days from order to delivery! Cardboard box was kinda beat up, but otherwise, shipment is fine!
5,164
I tried out my new to me Land Pride rear rake. Works well, and one wheel needs new bushings. They are made of plastic and cost $3.00 each, 2 required per side. Will pick them up on Saturday at the Kubota dealer.
Old_Paint
Dec 5, 2020
2,038
2,307
AL
Have ya thought about graphite impregnated bronze to replace them? You'd never have to lubricate them, and I'd bet they last a lot longer than plastic. If it's the wheels themselves, perhaps something with a ball bearing in it might be better suited. I don't like plastic bushings in anything that has to operate in dirt and dust, especially if it has to be stored outside when not in use.
How big a rake didja get? I'm thinking I need one to pull behind my LX for annual cleanup on the back side of my property. Needs to be at least 6 feet wide, but any wider, and I'm gonna have a lotta fun with all the trees back there. My problem is that NOBODY seems to be selling anything like that around here. Most of the used stuff I've seen at some of the 'local' auction houses is beat to crap and would cost as much to repair as it would to buy the implement new. Just haven't found the right person getting rid of the right implement at the right time, I guess. Those stars seldom align for me.
Siesta Sundance
Oct 23, 2022
1,835
2,545
youtube.com
Armstrong Ag, made in Texas, has some quality built attachments, many are built better than Land Pride!! Kubota dealer ordered it, I just waited till the dealership had a full shipment of attachments from Armstrong Ag. Took about 8 days, but no additional charge for shipping. The Armstrong AG 8' HD landscape rake has been a great asset, and I absolutely love it. Their website kinda sucks... but they do paint many of their attachments in Kuboter orange. Screenshot_20240320_085431_YouTube.jpg
Fast forward to 34 minutes, scraped clean about an 1/2 acre in minutes.
I prefer to have a crown on my gravel roads, the roads last longer IMO during weathering events. Harder the surface, slower the drag, but this rake is HD enough for this type of work as well.
11,757
I think you might be right. They are calling for 9 inches of snow Saturday. I put the rear blade back on and staged the blower if it's needed.
Nailed it!! 😂 We have snow in the forecast for this weekend, but it's nothing like what you're going to get. I had the pallet forks on the MX for the past couple of weeks since I had three things to move, but it's an easy swap to get the snow blade back on.
5,164
I took my snowblower off, and I am going with G-d put it there, let him take it away. To much work for this old body to keep putting the equipment on and off. Last fall I sold my snow blade that took the place of a bucket since I hadn't needed it for a few years.
