Kubota electric tractor
GrumpyFarmer
5,174
Once incentives and subsidies run out, I suspect manufacturers might start to remember that battery electric products start to lose power (output to do work) as soon as start using them versus a petrol that maintains power (output to do work) while using so long as fuel supply. I wonder why not make it safer and eliminate the PTO shaft behind the tractor if thinking about going to battery electric technology? Electric servos on the loader next? šŸ˜‰
6,601
Couple of weeks ago I went to a class on fire service response procedures and investigation considerations for fires and cooking off incidents involving batteries such as used in EV’s and storage banks used by utilities in conjunction with solar and wind. Part of it was a rather in depth dissection of this incident: https://fsri.org/research-update/re...red-lithium-ion-battery-energy-storage-system. Even if not fully involved, the chemicals being released in an overheating cook off situation are extremely toxic. Bottom line was once they are on fire or cooking off (overheated to the point of expelling gasses) you just have to stay back and try to keep the surrounding area from catching. That and if they’re cooking off in an oxygen poor environment do NOT ventilate even if they continue for days on end. And you best be wearing respirators if you’re within 100 yards of it upwind, further if downwind. All the while it’s dumping a smorgasbord of toxic chemicals.
In short, I have no interest whatsoever in battery powered cars, trucks, tractors, or similarly sized equipment as they currently exist. Hybrid: fine IMO. Large vehicles powered solely by batteries currently available are absolutely scary, even from the standpoint of ā€œsaving the environmentā€. Not saying they’ll never be viable, but they aren’t yet.
Someone somewhere has to be making massive sums of money off the EV mandates. If that isn’t the case, the level of stupid is at least a strong contender for one of the most idiotic movements in human history.
All that aside, zooming in a bit on that big chrome rear wheel, it looks like that’s a giant hubcap on a black steel wheel. Hopeful Kubota will make those things in sizes that will fit my L. If I could get some of those chrome wheel covers, hook some curb feelers to the loader subframe, fuzzy dice for the ROPs (we’re a little too old to be putting the wife’s lingerie up there), and swap out the OEM steering wheel for a chrome chain link wheel I could be styling and profiling while I’m out bush hogging, skidding logs, and blading roads. I can already bounce the front end (a little bit with the loader).
4,191
Jchonline
600
Red Feather Lakes, CO
Visibility looks fantastic. Maybe it will just have 360 deg cameras so you can react to whats going on around you a second after it happens. It basically looks like a lower profile Euro machine that they just threw an aerodynamic plastic cover on.
Jchonline
600
I watched a FD handle an EV fire in a home garage..they hooked up to the flaming vehicle, dragged it out into the driveway, then put this massive blanket on it to starve of Oxygen. All traditional extinguishing agents dont work. After it was out they put it on a flatbed tow truck with the blanket on and took it off. All FD were in full haz mat gear the entire time. The blankets were thousands of dollars each.
6,284
so the REAL money in EVs is coming up with a SYSTEM the fire departments can deploy to put OUT the battery fires !
I've given up on 'high car thefts'. emailed 3 dozen parties that 'should' be interested in HOW to 100% prevent theft of ANY vehicle by driving it away....... crickets.....
6,601
Oxygen starvation will stop the flames (i.e. ā€œput out the fireā€), which is vitally important to containment, but that doesn’t stop the batteries from continuing to release highly toxic gasses and there is no way to cool the batteries enough to stop them from continuing to cook off until all the fuel is gone. They aren’t technically ā€œburningā€ because there’s no oxygen necessary so it doesn’t meet the definition of ā€œrapid oxidationā€. They will continue the overheat cook off cycle even if they’re completely submerged in a lake/ocean. There is no way to stop that once it starts. It might stop on its own. Might not stop until there’s nothing left. I have to wonder if the tow truck owner/driver knew what kind of chemical meltdown they were putting on their truck.
4,191
I’ve never done it previously….but THAT post by Tzerne5…. just made me ā€œignoreā€ him…forever.
GrizBota
L3830HST/LA724, B2601/LA435/RCK54-32, RCR1872, CDI 66ā€grapple, pallet forks
Apr 26, 2023
1,147
733
Oregon
So it’s autonomous but still needs a human to hookup the top link?
I doubt it will happen other than on tax payer supported ventures.
The EV craze is past its prime, soon it will have to support itself on its own merit and that will be the end for now.
lynnmor
B2601-1
May 3, 2021
1,795
1,603
Red Lion
A government bureau is the nearest thing to eternal life we’ll ever see on this earth.
Jchonline
600
Yes the one I saw they had fire truck escorts for…..some good that would do lol
