Oil pan Plug thread size
9,776
Dustball
2016 B2650HSDC
Sep 15, 2023
467
326
Hudson, WI
ANYWAY - took the plug off and stuck the new .500 Fumoto plug in - goes in and does not even touch the threads! Big wtf moment!
I measured the major diameter and the minor - here are those numbers .536" Major -carefully measuring the OD of the thread and then measuring the minor diameter of the threads I got .492"
When you said .500 Fumoto, this means 1/2-20 Fumoto valve? That should not have dropped in if you measured the plug that came out at .536". Perhaps the Fumoto valve was the wrong size?
2,913
I wished I had taken a damn picture!!!
2,913
No, cause I have the exact valve - it was spot on. Something is just fishy - but hell,
I can't see it from my house! ;)
9,776
Why wouldn't a 1/2" threaded valve not fit into a ~9/16 hole?
2,913
here is the valve :
so the major diameter of the 1/2 -20 is damn close to .500 - the bolt that came out of the pan had an OD of .536 - so that .500 Fumoto went it without a twist!
9,776
Sounds like it's FUBAR to me! 🥴 :ROFLMAO:
GrizBota
Apr 26, 2023
1,147
732
Oregon
At this point you’ll need that plug in your hand to figure it out. Or just leave it as is.
2,913
I'm gonna hope I never see that freaking plug again - I didn't take it out nor place it back in - but I did make sure it was snug and a bit more.
lynnmor
B2601-1
May 3, 2021
1,693
1,488
Red Lion
It sounds like the drain plug was an oversized or double oversized repair plug that was installed by a previous mechanic. Yes, they make drain plugs to fix oil drains that were damaged by excessive tightening.
