General Lee's been hit!!!!!!! *******Updated with new Poll**********
I think that when RWS pulls that tube.........(I ,RWS, vow NOT to weld/braze it & I am not voting)
  • The tube will be cracked somewhere and he has to replace it.
    Votes: 1 4.8%
  • The tube will be bent, but he will bend it back, try to use use it. And it will NOT leak.
    Votes: 9 42.9%
  • The tube will be bent, but he will bend it back, try to use use it. BUT it WILL leak.
    Votes: 11 52.4%
  • Total voters
    21
  • Poll closed .
7,250
Can anyone decode the part number for the O-rings"?
https://store.germanbliss.com/Home/...m-h24000-hydraulic-pipe-hst-parts@04816-00120
I would like to have the properly sized o-rings on hand when I get it off, cause I'm thinking at least one is "toast".
Edit: I have a "generic" set of replacement O-rings in the shop, but these could be some sort of "special" ones that my kit might not have.
The chance you have the correct o-ring in thst kit is pretty low. I doubt its a "special" but there are a lot of standard possibilties both metric and imperial.
No dealer nearby? Kubota doesnt like to share things like standard o-ring size numbers in their parts manuals or numbering system....
Nicksacco
Sep 15, 2021
765
502
Bahama, NC
Maybe you've seen this already, but Messicks has this photo below. Looks like PN has changes too.
Another suggestion I've used in the past is to call a parts counter and ask them to measure the thing if they had whatever part it was in stock.
5,354
Gotcha,
I just ordered 4 of them. (y)
I just figured if I had them on hand, I would use them. No biggie though. Be here in a week.
4,202
I’ve been pleased with the myriad of repairs I’ve made with a HF assortment of O-rings I’ve had for 20 years. I just bought a new set of the same…. only for shelf-life concerns.… can’t seem to get motivated to open the cellophane…. I used the 20-yr old set again just yesterday to service a soda-water fire extinguisher.
Hkb82
Nov 17, 2021
418
330
Ontario Canada
I’d be concerned about it bending again now that the steel is compromised and weaker. For 100 bucks I’d be buying a new tube.
wp6529
B7100DT
Oct 31, 2023
156
99
TX
Being the "why buy when you can fix and make better than new" type, I would be inclined to remove the flimsy little tab and replace it with a more substantial machined block that would be unlikely to bend in the future (clean line and braze to new block).
5,354
Kicking it to the top to have a little fun.....
Poll added........
Hkb82
Nov 17, 2021
418
330
Ontario Canada
I had to choose 2 but I do believe it will be weaker the originally. More likely to bend again unless modified
4,202
Not enough choices.
4- Blown or dislodged gasket/o-ring and simply replaced them.
5-Tube will be bent and replacement leaks.
wp6529
B7100DT
Oct 31, 2023
156
99
TX
As this is not a pressure line, I think the odds of it leaking with new O rings and even a straightened tab are pretty low. Skid plates would definitely be a plus.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
Knowing your track record with hydraulics, I voted accordingly.
5,515
2,226
have done a bunch of those
get a new pipe. Almost impossible to straighten it. The tube itself is bent, something probably grabbed it and bent it. Getting it back to the perfectly correct shape is imperative for it to seal properly and getting it TO that shape isn't gonna be easy. I suppose if you have a lot of time on your hands it could be done. That's one of those situations where a customer would tell us "my gosh I could bend/straighten that thing in 15 minutes and put it back on and it'd be fine, why are you charging me an hour's labor at $150/hr to do a 15 minute job???" Because I've tried, and if you want me to try I will, but it will still be $150/hr and if it takes me 3 hours to straighten the pipe so that it will seal perfectly, it'll be $450 plus taxes fluids and fees. Or you can buy the pipe for $90 and I put it on for $150 plus fluids, and we'll be done. I had a guy tell me this about a battery. Said "I want you to put a new battery on while I wait"....(Kawasaki, NOT easy to get to on that particular unit). I said, leave it with me and I'll knock it out before lunch. Guy says no, I want it done NOW, it only takes maybe 10 minutes. Well, I probably made a mistake when I told him if it was that easy, just go buy a battery and put it on yourself. I can't recall ever seeing him back at that place again, and frankly I don't blame him. I don't do well with people who refuse to understand.
GrizBota
Apr 26, 2023
1,147
733
Oregon
I’m going with option 6:
Replace the bent tube as well as the O-ring(s). Then design and make a skid plate to protect it from the off-trail excursions.
Bending the tube sufficiently while in place on the tractor would seem unlikely given you’d not be able to get the remaining elastic rebound portion of the misalignment out. But you could always try since it was broken before you started…
5,354
Well I got some phone calls last night from my SIL and sister, so my weekend (and my hoist) just filled up rather quickly.
Looks like option 7 is the correct answer
Option 7: "RWS will be running around like a chicken with his head cut off this weekend working on peoples cars, so he is going to just order the damn tube and be done with it."
5,354
Yea, I think you guys are right.
I would like to try, but with the workload this weekend stacking up, I am better off just replacing it.
Any "helpful hints" to pass along?
In Utopia
L175 FEL
Apr 21, 2013
667
199
Utopia,Tx/Pasadena,TX
I may be wrong, but I don't think the problem is the tube as much as it is the piece of metal where the bolt is. It's bent away from where it's supposed to be flat against the housing.
4,202
I wonder if it wouldn’t be better to cut that tube near the flange….. flare it…and install a (flexible) hose to better take the occasional hit. (and might also be a better method than attempting to re-align or re-bend that tube.)
(Option #10…?)
GrizBota
Apr 26, 2023
1,147
733
Oregon
Looks a bit like a variant of Option 6 with no admission you’ve already conceptualized a skid plate. :LOL:
