Rats ate my wires
Dcarl74
ssv75
Feb 28, 2024
Tycson
Good day, I live in AZ and we have the wonderful pack rats that love wires. Im wondering if anyone has found where you could buy new plug ends for the solenoid valves. called dealer they said $4700 for new harness! ouch!
thanks
Hkb82
Nov 17, 2021
418
330
Ontario Canada
Ouch that suck to hear. Better also take care of them rats or your new harnesses and wires will end up the same. Here kitty kitty kitty.
OntheRidge
Nov 1, 2020
502
590
Maybe try these guys, they have everything.
Dustball
2016 B2650HSDC
Sep 15, 2023
521
384
Hudson, WI
Post some good clear pictures of the connectors and any lettering/numbers on them. I've been nearly 100% successful at finding connectors and terminals for my tractor.
5,515
2,228
we use Corsa Technic for connectors and wiring stuff. I have not found a connector yet that they don't have, or can't get. however, they'll often not show them on the website-you have to call them sometimes.
Most stuff on Kubota is just Bosch components, and use a lot of Delphi connectors.
Can you repair it? Even if they ate the wires off at the connector, sometimes you can de-pin the connector, repair the wire, and then reinsert the pin(s).
I deal with this stuff all too often at work on powersports stuff that sits all winter, and rats eat them up.
Nicksacco
Sep 15, 2021
770
504
Bahama, NC
I used Deutz connectors rebuilding my tractor.
They come in many different configurations and can be purchased on Amazon for example.
Excellent and waterproof. Just use care in the assembly.
Maybe you can just replace the connectors.
And for a bit of humour
6,323
He can't replace the 'connectors' that are actually molded into the solenoid valves ! Those ARE an integral part of the valve coil.
If he's really talking about the ssv75, lookup the valve on website,then ggogle the part number, might get a 'hit' on the MFR,then that website for 'mating connector'.
A posted picture narrows it down as does the list in the WSM.
In Utopia
L175 FEL
Apr 21, 2013
669
201
Utopia,Tx/Pasadena,TX
Saw some junk around my air compressor and couldn't figure out what was going on. Finally dawned on me, pack rat. Didn't even know they were in my area.
Set a trap with a dab of peanut butter and got him the first night.
John T
2017 BX23S 385XP Miller211 1952 Panhead Orange Ludwig 4 piece
May 5, 2017
1,345
866
under a rock
thanks
I had this happen to my wifes Ford Exploder
they chewed off the injector wire at the plug in.... Napa had a replacement.
anyway after that I installed 1 of these ultrasonic mouse repellers....
never had it happen again... and I saw no signs of droppings after install.
they were cheap so I figured it was worth a shot.
fenderbender
BX23s
Feb 29, 2016
52
TOCCOA. GA
This is what I use after they chewed the wires up in my wifes Toyota FJ Cruiser. The bill at Toyota was $1600.00.
5,164
Mice chewed the one wire on my Mercedes that controlled the transmission shifting. The insurance company totaled the car rather than fix it. They said that the last time they sent a Mercedes to the dealer for a chewed wire, the bill was over $10,000, double the original estimate.
6,323
I've got a $2000 Echelon Connect 'fit bike' (fancy exercise bike)...needs a connector and sensor(little mice here NOT big rats...,smaller wires....) anyway .... IF it was under warranty, entire unit get replaced, free of charge. Hmm, 4 months over so... it's now LANDFILL ! Echelon doesn't sell 'parts' !!!!
Yeesh, talk about a 'disposal society'...
so.....
ASK about replacement parts on ANYTHING you buy,before buying it.
Togo
M4-71
Feb 29, 2024
East Pine, Louisiana
I went to the pound and adopted a few working barn cats. I buy 40 lbs of cat food at tractor supply every six months. Great investment.
lynnmor
B2601-1
May 3, 2021
1,821
1,622
Red Lion
It should be mentioned in this thread that wiring insulation is now being made from a soy based product. Brilliant move making wiring from food. It is bad enough for automobiles, but tractors often are stored in barns or out buildings where rodents often reside.
4,238
some unknown predator (owl?) ate my cat
I’ve put out Tom Kat blocks in every corner of every bldg/garage/shed/etc
5,188
Decon,....or an equivalent, will work great, and is inexpensive.
Dcarl74
ssv75
Feb 28, 2024
Tycson
thanks
Thanks for all the replies! I found the wire connectors @ Findpigtails.com they have about every connector known to a man, I sent them pics of the connectors and they replied quickly! 80.00 each not cheap but better than the whole harness!!
Dcarl74
ssv75
Feb 28, 2024
Tycson
yes sir you are correct the solenoid does have a molded plug on it but the harraness is a plug that plugs into the solenoid I found the plugs @ findpigtails.com
