i am a newby having trouble with an aftermarket 3 point kit working with cat 1 implements on my jdm b7000. i am wondering if i have set this up wrong or the hitch kit is the wrong size? i have compared the 3 point mount point to a friend's b7100 and they seem to be identical width so i think the issue is either my setup or the kit.
the problem is it is very hard to spread the arms to fit the implements and when you finally do and then bring it in the outboard check chains interfere with the tires on uneven ground or corners. this is on 26" wide (inside) cat 1 implements and the problem is the same on three different implements.
i have tried various levelling arm settings and i find i can't adjust the check chains more than a partial turn beyond minimum length. it seems like the lift arms are too short to achieve the correct spread without tire interference but this 3 point kit is specifically sold for the small b series tractors and i believe i am correctly installing the check-chains according to the instructions.
