Kubota D1105 Injection pump cracked
6,380
Are all the parts in it come from the old block?
Did you do the rebuild?
6,380
Yes, all came from old block. I did do the rebuild.
Do you still have the old block?
And why did you need to replace the block?
Sorry for all the questions, but nothing pops out as a cause yet.
jayp1017
Kubota D1105 Grasshopper
Feb 25, 2024
21
I have the old block. Reason I replaced the block is because I had a combo of things happen. Started as a cracked head and colant plug coming out on radiator as I was mowing air strip...this cracked the middle cylinder causing melt down...I bought kit to rebuild and resleeve but ended up finding a new block by chance...which was a whole lot more appealing than resleeving/machining the old one. I'm beginning to think your just asking me questions to improve your page status 🤔 😉 lol...anyhow, I'll take the questions if it may lead to the answer.
6,380
ok one more set of pictures
Fuel cam.
Here is what I'm thinking, that this bearing is not in the right position and the fuel cam is hitting the body of the pump and not the roller.
This wear mark makes me think something is off.
I also really don't like these marks
5,571
Now that right there is hilarious! Only a newbie would say that.:LOL:
jayp1017
Feb 25, 2024
21
Fuel cam.
You are a genius! I now remember I over tightened a bolt on the bearing retainer plate (part #90) and broke off one of the hex bolts...there are two of them and one I sheared off but forgot about it in my haste to get it back togeather. Man I tell ya little things like this really come back to bit ya in the ass! I'll report and take a few pics when I get the engine pulled back out of the machine tomorrow. I'm sure this has to be the problem as it makes the only logical sense!
jayp1017
Feb 25, 2024
21
Fuel cam.
well I took a look at the cam from the top and there is very slight movement of the cam from side to side but I don't believe enough to justify that as being the issue. hummm?
jayp1017
Feb 25, 2024
21
I do see that bolt to the right sticking out a bit but I don't think that is causing the issue either
5,066
LOL I was being a smart ass...Glad it brought a smile to your face!
I think MOST of us DID realize that you were intentionally being a smart ass. :)
We ALL do know that NIW is the Einstein of the Kubota world.
GSD-Keegan
B2601 with Fel and Bh70 backhoe
Mar 6, 2021
611
808
Ontario, Canada
Can see corresponding marks on that cam that most likely are from the bottom of the pump as wolfman pointed out. I think I would try to get a deck height from the new block and compare that too the old block.
6,380
Pull the shims and put a straight edge across the block just above each bearing, and measure from the top of the bearing to the bottom of the straight edge and try and get a good measurement.
The do the same from the old block.
Tolerances are very tight, so any movement at all can be very harmful.
A stuck or blocked injector should not cause this, but anything is possible.
Do you think you have one that is stuck?
We can test for the when you get the new pump.
When you get a new pump we can do some tests before you run it.
jayp1017
Feb 25, 2024
21
Pull the shims and put a straight edge across the block and measure from the top of the bearing to the bottom of the straight edge and try and get a good measurement.
I will do that...problem is the old block isn't in my possession currently so I'll have to take a trip to go get it. Curious tho, would a bad injector cause the pump to crack like this? It seemed to run on all 3 cylinders but above 70% power is when catastrophic failure happened. Idk I'm grasping at straws here.
6,380
Reread above, I did edit and add...
Coffee has not fully kicked in yet!
